Search Results (Searched for: gs swing arm)
That's a nice gesture to do for an old past friend! Early style drag bikes are very simple. Plenty of parts are floating around regular on eBay. I know 3 guys in Ohio, A guy in Topeka, KS. As your finding out all these old bikes were mis-matched hybrids of parts The engine with the "E" says Mark II case. I always buy shaft drive 1000's for the cases when I can. I have a few saved. But with a 16 tooth bottom pin in center of crank, crank is welded! with a 124 tooth cam chain, then 32 tooth cam sprockets. You got to be careful when putting these old engines together with different parts. When this is all apart show us the engine pics! BUT I would not think the CC's are that big 1428?? that is a lot of modifying! Lots of oil leaks with those big cylinder liners and bored out cases But good bones. Nice wheels that will polish up like new! Nice swing arm.
Please! RAKE the frame neck! (I'll post a pic of mine!!! jpg[/attachment] ]100_1563.JPG[/attachment] ) It needs to for the classic drag bike look!
And change the Z1R Tank to smaller LTD tank, (But if it was your friend who wanted that tank?) then keep it!!!
Then, I would down size to a 1075cc .410 lift cams that use shim on top like stock oem's. More rideable on the street if you plan that? Or will you drag race it only?
Spend some time and give us a story and your ideas.
I gave up on this stuff, life is too busy and I'm old and broken & worn out!. I sold off most my good parts. But have a couple things sitting for too many years! Yea! I know! read and heard all about those wasted project bikes. Plus I hang with some Nostalgia A/A Gasser Guys that go up the around the east coast.
But nice choice! Build that Old KZ like a Pro-Stock bike from the late 70's. There are plenty of fabricators on this site that build items now. A lot of guys here on this site that know a lot of other guys all over the country. But Dragbike style is not on top of list on this forum.
Replied by Street Fighter LTD on topic Bike of the Month.
14 Oct 2017 15:06
More bike info
Handlebars and grips are from Airtech. They are Clubmans installed up side down to raise them up just enough.
Frame is braced by Chuck from Logghe Chassis. Chuck built many Kaws and raced them . He was very well known and respected for building race car chassis for big names . Google Chuck and see. The frame has a few braces you wont see any where else due to his direct feedback race experience. Steering neck has tapered roller bearings from All Balls and I run twin steering dampeners from Kawasaki. Rear fender is moved back 2 inches with a hand made aluminum bracket in preparation for a new swingarm which is planned
All body work is original
Replied by 650ed on topic New Member from San Francisco
10 Oct 2017 08:50
Welcome aboard -
Here are some tips that you may find helpful. If nothing else be sure to read the advice about JIS vs Phillips screws.
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my homemade modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX (and pretty much all AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes, but things have changed. Zinc and phosphorus additives (ZDDP), important to protect engine components from metal to metal contact, has been reduced since it’s been found to shorten catalytic converter life. Today’s auto oils contain about ½ the ZDDP they used to and different additives have been developed as substitutes. Unfortunately, some of these newer additives, in particular molybdenum disulfide, don’t get along with the wet clutches in our bikes. Newer oils, especially those labeled “Energy Conserving” (EC), which have a high quantity of friction reducing additives, should be avoided. These oils work fine in automobiles but there are better choices for motorcycles.
KZ bikes need oil which is suitable for wet clutches. That distinction was defined by the Japanese Engine Oil Standards Implementation Panel (JASO), and can be noted by oils that meet the "4T” (4 cycle) specification, MA (wet clutch) classification. These oils, which include various synthetic, semi-synthetic, and non-synthetic oils, are sold as specific motorcycle oils. Another type of oil which works well in our bikes is diesel engine oil. These oils are governed by the API (American Petroleum Institute) CI-4/CJ-4 spec and don’t contain clutch-damaging EC additives. You can even purchase Shell Rotella oil which holds a “JASO-MA” certification assuring it will get along well with your wet clutch. All of these newer oils have a reduced ZDDP level too (about 1/3 less than before instead of ½ like the auto oils) but the substitute additives get along better with our bikes needs than automotive oil. Oils that do not hold the JASO-MA rating have either failed the wet clutch test or have not been tested for use in engines with wet clutches. Good luck with the bike! Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
Getting my KZ project together. was created by tomsbadkz
08 Oct 2017 08:55
Well, Im finally getting it assembled. Frame, swingarm, and all of the small parts were stripped and powder coated satin black. Im doing every bolt and nut new. Im using mostly stainless hardware. As you see, It is stretched out 13" from stock. Myrtle West jackshaft swingarm from a GSXR 1000. It has air in arm for my air shifter. I had brackets welded to the arm to keep the twin shock setup instead of a mono shock. Made caliper stay from aluminum as alot of other things have been lightened to accommodate the added weight of the arm, 10.5" rim and 300 tire. 5 spoke front early GPZ305 rim sent to Pauls Chrome to be chromed and looks almost identical to the Rear Weld Racing rim. Gonna get started on the motor next. Have to get with my motor buddy for some help on that. So, what do ya guys think so far?
I've owned my 1977 KZ650-C1 since it was new (April, 1977); my bike is stock for the most part. It has more than 60,000 miles on it and has never needed any engine work or other serious repairs. I did replace the steering stem bearings with tapered roller bearings and the swing arm bushings, but that was not really a big deal. The original shocks were never great and they wore out rather quickly, but again replacing them with better shocks (I have Hagons) is not big deal. If the bike in question is stock, has not sat unused or neglected for an extended period, and has received normal maintenance it should be fine. If, however, the previous owner has made changes to the bike it may be unreliable. I suggest you take it for a ride and see how it performs. Ed
Replied by DOHC on topic 1979 KZ650 SR1
04 Oct 2017 20:16JWKZ750 wrote: So i passed on the 1979 and got a 77 which doesnt have the emission stuff the 79 does.
It looks like you got a nice bike. I like those aftermarket Lester mags. A cool period upgrade. By the way, my very first bike was a '77 Kz650.
I also thought I'd note that the '77 Kz650 (B1) is a bit different from all of the later 650s in a number of ways. Here are some changes from the '77 B1 to the '78 B2 from kz650.info
www.kz650.info/kz650files/adobe/KZ650_History.pdf
The front brake caliper was reversed to the back of the fork leg and the front master cylinder was changed from a round item to a triangular one. The charging system was changed from a three-phase system to a two phase and the regulator and rectifier was now a combined unit. The cam chain tensioner was changed to an automatic unit and a hazard switch was added to the left-hand switchgear. Needle roller bearings were now used in the swing arm instead of the previous model bushes and slight modifications were made to the carburetors to improve low speed operation. The fuel tap was replaced with a diaphragm type unit. There were also slight detail changes to the outer engine cases to incorporate the new lower case Kawasaki logo. The front footrests were now rubber mounted to combat vibration and the front forks were slightly modified.
Replied by scubaanders on topic Pivot tube length of kz750e swing arm
02 Oct 2017 12:27
Will Call the first them tomorow. Any thing else from Denmark while we are at it.?
Pasties? Red hot dogs? Smörrebröds? Ugly duckling? Or a mermaid?
/A
/A
I have been getting pm requests eager for history so I will start now.
Suzie was brought home from Intercontinental Kawasaki in the early Spring of 1978
Paid about $3,500.00 Dollars Cash.
I knew I was going to buy this model as soon as I sat on the seat and grabbed the handlebars as I felt She was a perfect fit.
With in 2 months I bought a set of 29 mm smoothbore carbs and pod filters. Jetting was done by my bud Ted and I with little difficulty.
Ted had purchased a new 78 Z1R a month before I bought my LTD. We were constant riding/ wrenching buds and fast friends.
So at first the Z1R could edge me out once we hit about 60 mph , but the 26 mm stock carbs worked better up until that point.
The 29 smoothies were my answer to being beat and they made us dead even and we verified that fact at about every stoplite.
Ted and I went on to help and crew for our friend Kevin Tooma who became our team owner with his dads help in funnybike and topfuel racing for the next 10 years.
So Ted put a Winning brand 4into 1 headr on his bike ( NAMED STANLEY ) and the battle was on again . He started beating me again so back to the bank and I put what I felt was a better pipe on Suzie. This was the Yoshimura Road racing pipe and
I now held the advantage again
Ted and I continued to up the ante every few months for the next year or so. Changes in gearing , 1075cc , 1200cc,
welding cranks, backcut transmissions , head work , dragslicks , struts and wheelie bars
BOY oh Boy did we have fun . We got good deals and free run of a number of machine shops, and discounts on parts
as we were a force to be reckoned with and we would put shop stickers on our swingarms and promote our sponsors.
Skipping ahead for a moment Ted and I went to a new bike dealer unveiling once at Andersons cycle in Bloomfield on Telegraph road to see the new bikes at Michigans largest dealer. Of course we rode our bikes. We were inside checking out the new bikes when the dealers general manager came up to us and asked us to leave the premises as the biggest crowd was outside checking out our two bikes instead of looking at the bikes he had for sale...LOL Proud moment LOL
Those were good times and great memories of times gone by..
Next chapter is real racing . I promise to scan some old photos and share them soon.
So Kevin , Ted and I became traveling team members running alot of sanctioned events east of the Mississippi in funny bike.
Our home track for testing and fun was Milan Dragway. Cliff the owner loved when we came out as he knew we were a draw for the local bike scene. Our first real race bike was a Kosman built frame , laydown chassis with a 8 inch slick. We called it the little digger. Another member here Ralph Pitlock from Paintworkz did Kevins paint on all his bikes including our honda pitbike.
Nice work Ralph. Best painter I know...
So anyway we had lots of fun and won a lot of races . WE were blessed with Kevins dad Doc Tooma who had deep pockets and spent a lot of money on making our team competitive.
We would show up to a race with our bike and spare motors and parts to build a couple more motors if needed. .
MORE LATER
MORE LATER
Replied by Markovich on topic My 1990 KZP build
30 Sep 2017 14:43
So, fast forward to now, I decided to take the bike apart. It was smoking on start-up and knocking a bit so I tore it down to parade rest. Engine out and down to frame. Powder coated the frame, swing arm and battery box. Changed out to chrome front fender. Rebuilt the engine. New rings, hone ecg. New seals in the head and lapped the valves. Engine is back in and tank is drying. Working on the wiring now. Still need a seat. I think I'm going to go with custom build on it. Some pics for you.
Replied by les holt on topic Pivot tube length of kz750e swing arm
25 Sep 2017 17:13
Alright guys, I just purchased 100 needle bearing internal races and 4140 DOM tubing. In the industry we frequently used the races to repair shafts that ran needle bearings and with the strength of the 4140, I can make a sleeve that's both durable and cost effective. I'll be doing some proving this out for a while but I'm highly confident this will provide a replacement for these shafts. When I make the first ones, I'll post up pics and progress.
Les Holt
PDM Custom Fabrications
Les Holt
Displaying 731 - 740 out of 7255 results.
