Pivot tube length of kz750e swing arm
- gixxerkidd03
11 Sep 2017 13:31
Look for the length of the pivot tube on a kz750e/h. Thanks
1981 KZ750e
Re: Pivot tube length of kz750e swing arm
11 Sep 2017 14:51
Could not found the correct length but with some math you can get a real near by length.
Swing arm tube width #4 - (4 x needle bearing width #3) = pivot tube length #6
- gixxerkidd03
11 Sep 2017 15:15
hmm that may help, I guess more then anything im looking for the measurement from inside the frame im designing a sleeve for a swing arm conversion and don't have my bike torn apart yet.. thanks
1981 KZ750e
11 Sep 2017 15:30 - 11 Sep 2017 15:39
Here are some swing arm charts
swing arm/pivot to frame width in metric mm
swing arm wheel width in metric mm
Länge = swing arm length = pivot to rear axle in metric mm
The values in brackets refer to the pivot or axle OD in metric mm
Last edit: 11 Sep 2017 15:39 by Scirocco.
- scubaanders
11 Sep 2017 21:56 - 12 Sep 2017 06:14I stated 232 earlier, but thats on the Zepyr 750.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Last edit: 12 Sep 2017 06:14 by scubaanders.
- gixxerkidd03
17 Sep 2017 21:17
Thanks. Ya the measurement I was looking for was the inside of the frame, from boss to boss. Which your right, is 230mm. I cut down a welding rod until it fit perfectly than measures it. I wasn't sure how much the kz rubber end caps took up. Thanks, I'll be give that measurement to my machinist tomorrow to finish my new sleeve
1981 KZ750e
- turboguzzi
21 Sep 2017 16:15
did you source a 16 ID X 22 OD sleeve from some other model that can be cut to length?
a 750E im buillding into a road racer needs a new sleeve....bearing area totally rusted/gone
can measure the original length if you need
- undiablo
22 Sep 2017 07:37
In case you need them, Kz750 has 4 HK2216 needle bearings (22-28-16).
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- turboguzzi
22 Sep 2017 11:20
this 750E is in pieces so here are the dimesnions i got
sleeve 226mm
gap when in the frame is 5.7mm internal distance is 261.7mm
diablo, wish the problem was the bearings! those are easy to find, it's the sleeve that goes bad and it doesnt exist anymore as a spare
sleeve 226mm
- undiablo
25 Sep 2017 15:59
I had the same problem. Ended up stick welding the bearing area and turning in the lathe.
- les holt
25 Sep 2017 17:13
Alright guys, I just purchased 100 needle bearing internal races and 4140 DOM tubing. In the industry we frequently used the races to repair shafts that ran needle bearings and with the strength of the 4140, I can make a sleeve that's both durable and cost effective. I'll be doing some proving this out for a while but I'm highly confident this will provide a replacement for these shafts. When I make the first ones, I'll post up pics and progress.
Les Holt
PDM Custom Fabrications
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- scubaanders
25 Sep 2017 21:30
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
