Advanced Search
Search Results (Searched for: gs swing arm)
Replied by GKBO on topic Swing arm sleeve on my 82 GPz750
04 Apr 2016 08:22 - 04 Apr 2016 08:25
GKBO's Avatar GKBO
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
swest wrote: Looks good. What are the inside/outside dimensions?
Looking at the 78-9 KZ 750 fiche the needle bearings are the same HK2216 the GPz has so the OD is 22mm .OK there isn't an extra seal on the twin.The pivot bolt number of the twins is 33032-047,the KZ650-750's is 33032-050 and the GPz's PN is 33032-1028.The same 33032 makes me think they're all the same basic bolt with the second number denoting a different finish,the GPz and later KZ750 bolts have a black finish and the others are silver.That long winded explanation ends us up with a 16mm ID to fit the 16mm x 310mm pivot bolt.Yes I have been thinking about this A LOT ;)
Just a funny story I ordered this pivot bolt out of Potsdam(A famous suburb of Berlin) Germany.The sleeve is coming from Berlin to,Berlin Connecticut.Add in that my German heritage and it all strikes me as being funny as heck.
03 Apr 2016 17:46
GKBO's Avatar GKBO
No eBay APP ID and/or Cert ID defined in Kunena configurationI ended up buying this
the bolt is the same spec as the GPz,so are the seals and bearings.Pretty sure it will fit right in.
Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
Replied by GKBO on topic Project 82 GPz750
03 Apr 2016 17:36 - 03 Apr 2016 17:52
GKBO's Avatar GKBO
[IMG
A BIG one off the list :cheer: Degreased the frame a couple of weeks ago. I wire brushed off most of the rust then used my spot sand blaster to get the bits the brush couldn't get to.Then sprayed on 2 coats of this www.rustoleum.ca/product-catalog/consume...alty/appliance-epoxy .Used it before and it's great frame paint!Se the last post here www.kzrider.com/forum/5-chassis/601411-s...eeve-on-my-82-gpz750 and this has come to with some bearings coming from China .
Kz550 wheel rotor? was created by chris_heiges
28 Mar 2016 19:58
chris_heiges's Avatar chris_heiges
Ok so I have a 1980 kz440 that I'm doing a lot with, one of those things is to convert it to disk brake in rear. Now I already have a wheel that fits close enough to space to fit it's a 1983 kz550 16" rear wheel. This is all I know about the wheel. It did not come with the rotor or sprocket assembly. I have acquired the sprocket assembly but now I need a rear rotor and caliper to proceed with the swing arm modification. I can not find a rotor for this wheel. I have called local stores and they say that they don't list a rear rotor for that year make model. It has a 4 bolt pattern for the rotor and is about 3" diameter from outside bolt hole edge to opposite edge. I just need something that will fit this pattern and I can get a matching caliper.
Does anyone have any clues for me as I have been googling for days on this?
Replied by 650ed on topic Brand New Rider and New Owner of 1983 KZ750 LTD
28 Mar 2016 13:36
650ed's Avatar 650ed
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
[IMG
PICTURE 2
[IMG
PICTURE 3
[IMG
PICTURE 4
[IMG
PICTURE 5
[IMG
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
Replied by jowek70 on topic 77 kz1000 engine build
27 Mar 2016 12:41
jowek70's Avatar jowek70
kaw-a-holic wrote:
jowek70 wrote: Mock up day
What front end is that? FYI I used a 92 GSXR front end and it's to short. From what I have read ZX9 is the way to go.
Front: 94-97 zx9 forks, zx9 triples with kz stem, zx9 clip ons, zx9 front wheel, axle, rotors and calipers.
Rear: gs1100e swingarm, gs1100e JSB shocks, 94-97 zx9 rear wheel with different bearings to run gs1100 rear axle. Still figuring out spacing on the rear and a rear brake set up.
Replied by davido on topic CSR1000 Project Build
26 Mar 2016 12:09
davido's Avatar davido
Yup.Im well happy about it. Things are moving. Got the wheels and the swingarm out to send to the powdercoaters. Expected to take 2 weeks (+ - ).Went on the interweb to price up all the bearings and seals Ill need to put them together again and nearly had a heart attack.So,I went off to a local bearing suppiiers yesterday and got most of what Ill need at a far better price. Still have to get genuine dust seals for the wheels and needle bearings for the swingarm.
Had at it this morning and hit an old problem with the rearsets. Frigging sidestand is going to be in the way of course. Mostly the spring.Ill have to figure something out there.
Bugger.
Replied by theApehouse on topic How hard is it to convert police KZ1000 to naked?
25 Mar 2016 19:10
theApehouse's Avatar theApehouse
swest wrote: I'm keeping my eyes open for a KZP in my price range. That's what I'm going to do. Modern suspension like the ones here and Z1 style bodywork. B) The frames are stiffer than my Z1 and if my swing arm mod works out, I'll make one for it too. One hell of a CYN carver and street fighter. I could thrash the SHT out of it and give Bossie a long deserved rest. :evil:
Not sure how far it is from you, or your price range, but this KZP popped up on my radar today(so to speak :whistle: ) losangeles.craigslist.org/ant/mcy/5508401158.html
If that mileage is accurate(and a 2nd owner should theroretically have paper work to prove it) then it sure seems like a great price to me. There's a kzp here locally with similar mileage and they'r trying to get double this price. Granted, I'm not sure they will..
Replied by BohicaBob on topic GS1100 swingarm swap wheel and brake options
25 Mar 2016 10:54 - 25 Mar 2016 10:55
Replied by SWest on topic GS1100 swingarm swap wheel and brake options
25 Mar 2016 08:13
SWest's Avatar SWest
Got a link for the Race Tech emulators?
Displaying 1091 - 1100 out of 7257 results.
