Swing arm sleeve on my 82 GPz750
- GKBO
- Saving old"dead" bikes
Re: Swing arm sleeve on my 82 GPz750
01 Mar 2016 14:15
Well that idea hit the bin,the piece I thought was the right size is oversize both ways :S .I have bushings from the GS750 arms to,the right ID but the walls look to be 1mm bigger :dry: I got a guy who could weld it up at work but nobody I know has a lathe.Well at least not in the Victoria area
01 Mar 2016 16:01
There are a LOT of KZ750 swingarms on ebay which use the same sleeve. How about contacting some sellers and ask them to pull the sleeve and inspect it for wear? I'd also ask them if they will reduce the shipping cost if you bought the whole assembly but only shipped you the (lighter) parts you need.
- GKBO
02 Mar 2016 03:54
Yeah that might work Ed but not right now.This will have to wait a bit as I have things that need to get done here first.
- GKBO
06 Mar 2016 09:56 - 06 Mar 2016 10:13
No eBay APP ID and/or Cert ID defined in Kunena configurationWhat about these? Do they replace the needle bearings?Would still need a new sleeve right?Looks like it would replace the seal?Seems odd that it fits the old smokes and the GPz/KZ's :dry:
Last edit: 06 Mar 2016 10:13 by GKBO.
- GKBO
13 Mar 2016 15:44
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
If someone knows the width of bearing on this list
KAWASAKI KZ 1000 J Sports 1981
KAWASAKI KZ 1000 J Sports 1982
KAWASAKI KZ 1000 K LTD 1981
KAWASAKI KZ 1000 K LTD 1982
KAWASAKI KZ 1000 Police 1982
KAWASAKI KZ 1000 Police 1983
KAWASAKI KZ 1000 Police 1984
KAWASAKI KZ 1000 Police 1985
KAWASAKI KZ 1000 Police 1986
KAWASAKI KZ 1000 Police 1987
KAWASAKI KZ 1000 Police 1988
KAWASAKI KZ 1000 Police 1989
KAWASAKI KZ 1000 Police 1990
KAWASAKI KZ 1000 Police 1991
KAWASAKI KZ 1000 Police 1992
KAWASAKI KZ 1000 Police 1993
KAWASAKI KZ 1000 Police 1994
KAWASAKI KZ 1000 Police 1995
KAWASAKI KZ 1000 Police 1996
KAWASAKI KZ 1100 B GP 1981
KAWASAKI KZ 1100 B GP 1982
KAWASAKI KZ 750 K LTD 1983
KAWASAKI KZ 750 K LTD 1984
KAWASAKI Z 1000 J KZCJ1BA 1981
KAWASAKI Z 1000 J KZT00J 1982
KAWASAKI Z 1000 K LTD KZCK1BA 1981
KAWASAKI Z 1000 K LTD 1982
KAWASAKI Z 1000 Police 1982
KAWASAKI Z 1000 Police 1983
KAWASAKI Z 1000 Police 1984
KAWASAKI Z 1000 Police 1985
KAWASAKI Z 1000 Police 1986
KAWASAKI Z 1000 Police 1987
KAWASAKI Z 1000 Police 1988
KAWASAKI Z 1000 Police 1989
KAWASAKI Z 1000 Police 1990
KAWASAKI Z 1000 Police 1991
KAWASAKI Z 1000 Police 1992
KAWASAKI Z 1000 Police 1993
KAWASAKI Z 1000 Police 1994
KAWASAKI Z 1000 Police 1995
KAWASAKI Z 1000 Police 1996
KAWASAKI Z 1000 R 1982
KAWASAKI Z 1000 R2 KZT00R 1983
KAWASAKI Z 1100 GP B KZT10B 1981
KAWASAKI Z 1100 GP B KZT10B 1982
KAWASAKI Z 750 K Ltd Twin Belt Drive KZ750K 1983
KAWASAKI Z 750 K Ltd Twin Belt Drive KZ750K 1984
I'd like to know.Suspect they may be wider than the 16mm of the HK2216 that the fiche conveniently tells me they are.Have no problem installing wider bearings.
I keep forgetting the KZ750 twins,I think that's what the bronze bushings are for. Speaking of the twins I found these for the 83/4 twin belt drives and later 1000/1100's.The pivot bolt and seals are the same PN as the 82 GPz750 so if I cut my sleeve as a spacer and it should be good to go..At 1/2 the $$ of the other kit it's easier on the finances.GKBO wrote: What about these? Do they replace the needle bearings?Would still need a new sleeve right?Looks like it would replace the seal?Seems odd that it fits the old smokes and the GPz/KZ's :dry:
- GKBO
03 Apr 2016 17:46
No eBay APP ID and/or Cert ID defined in Kunena configurationI ended up buying this
the bolt is the same spec as the GPz,so are the seals and bearings.Pretty sure it will fit right in.
03 Apr 2016 18:08
Looks good. What are the inside/outside dimensions?
- GKBO
04 Apr 2016 08:22 - 04 Apr 2016 08:25
Just a funny story I ordered this pivot bolt out of Potsdam(A famous suburb of Berlin) Germany.The sleeve is coming from Berlin to,Berlin Connecticut.Add in that my German heritage and it all strikes me as being funny as heck.
Looking at the 78-9 KZ 750 fiche the needle bearings are the same HK2216 the GPz has so the OD is 22mm .OK there isn't an extra seal on the twin.The pivot bolt number of the twins is 33032-047,the KZ650-750's is 33032-050 and the GPz's PN is 33032-1028.The same 33032 makes me think they're all the same basic bolt with the second number denoting a different finish,the GPz and later KZ750 bolts have a black finish and the others are silver.That long winded explanation ends us up with a 16mm ID to fit the 16mm x 310mm pivot bolt.Yes I have been thinking about this A LOTswest wrote: Looks good. What are the inside/outside dimensions?
Last edit: 04 Apr 2016 08:25 by GKBO.
04 Apr 2016 08:45
I'll measure my bushings when I get home. I screwed up one drilling it so the 16mm hole is sloppy. Do you still have your old one/ I may be interested in it to cut and make a new bushing out of it. :whistle:
- GKBO
04 Apr 2016 10:03
If I don't need it Ill send it to you for shipping.I'm in Canada so I'm not sure if shipping will be to much.
04 Apr 2016 10:08
Thanks I'll check when I get home.
04 Apr 2016 18:19
It won't work. I've got 20mm OD and 16mm ID. Hold on to it, Jeff may be able to turn it on his lathe that is unless it's too hard.
