Kz1000 Carbon Fiber Fuel Tank
- porchev914
Re: Kz1000 Carbon Fiber Fuel Tank
29 Sep 2010 08:00
It absolutely is a consideration Mark. The Chinese cap I referenced has a vent built into the cap ala stock Kz cap
FRANKEN Z!
- trianglelaguna
29 Sep 2010 08:06
man iwas all happy...a black tank with white kawasaki tags and a shiny chrome cap ...it begs old school high tech.......go ahead ,,,it's your bike...put a turdpuncher filler cap......how about some red grips while your at it....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
29 Sep 2010 08:13
trianglelaguna wrote:
LOL.:laugh:
Don't be holding back there bud.
:laugh:
LOL.:laugh:
:laugh:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- trianglelaguna
29 Sep 2010 08:15
i was trying to remember if you had red grips that sled of yours... oh well,took a shot hope it did not crease anyones implants
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
29 Sep 2010 08:22
no i just put new gold grips on. but the red is a great idea.
thanks. :laugh:
thanks. :laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
29 Sep 2010 09:13
I thought about a stock fuel cap, but the reality is it would be significantly more difficult to pull off. The stock cap requires a hinge and latch point on the tank which would need to be steel. That would mean manufacturing new hardware and laminating it in place. This would necessitate a special, rather complex mold that I'm not sure how I would make. Sure Craig, the stock cap would look cool. But the bottom line is I am not capable of that complexity yet. Soooooooo, I'm taking the easy way out. The turdpuncher way
FRANKEN Z!
- Becker
- The Doctor Will Rise Again
29 Sep 2010 14:16Soooooooo, I'm taking the easy way out.
Ya, the easy way out, thats why you're making a custom carbon fiber tank. Because it's easy.
The stock cap would look cool but I think it would look better with a flush filler cap. It would just blend in and not draw attention away from the c-f.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
29 Sep 2010 14:56
I think a Z1R cap would be cool............
- porchev914
02 Oct 2010 20:43
I like the durability of these carbon kayaks...
FRANKEN Z!
- kzz1p
03 Oct 2010 00:04 - 03 Oct 2010 00:08
porchev914 wrote:
I saw that Kayak in another video. That finish is fiberglass matt, then a CF layer over it. I like that finish. Those boats weigh less then 26 lbs.
In that other video the guy had a cool dye grinder. It had a little "Saw Table" for trimming stuff.
Last edit: 03 Oct 2010 00:08 by kzz1p.
- porchev914
07 Oct 2010 13:11
As exciting as the main parts of the tank are, there are a couple of less glamorous pieces that require molding as well. That would be....you guessed it, the tank mounts :silly: Some of you may remember that I had to cut off 14 spot welds to remove 3 parts. In order to mold from these brackets, I needed to fill in the holes left by the cutter.
I put masking tape on the back of the holes to make a floor, allowing the body filler to stay in the holes until it sets.
FRANKEN Z!
- porchev914
07 Oct 2010 13:18
I skipped a couple of steps here, just to show a little quicker progress. Here are the brackets with the holes filled and the first couple coats of primer sprayed.
Next I'll smear on a thin coat of spot putty to fill in some minor imperfections. After smoothing that out I'll apply the last couple coats of primer and prep for molding. I'll do the molds for the brackets at the same time as the tail, so hopefully in the next 2 weeks.
Tip- close observers will notice some minor fish eyes in the white primer. This is due to surface contamination, and improper cleaning prep prior to painting. If you are painting something that will be visable, proper preparation is an absolute must to avoid defects like this
FRANKEN Z!
