Knee Dents in the stock tank... PHASE TWO CUTTING DONE!!!!
  • twowheeledterror
  • twowheeledterror's Avatar Topic Author
19 Dec 2005 23:16
#13805
Well, this is going to be like the see thru clutch cover post. It's gonna be done in phases while I go to it and have time.
PHASE 1: TRACING OUT YOUR CUTOUTS FOR KNEE DENTS/TUCKS!
So what do you need?
-Silver Metallic Marker
-Paper (thicker stuff, standard drawing paper works good)
-Scissors
-Pencil
-Ruler
-Masking Tape
Okay, so a quick description. You're gonna lay up a "stencil" on the tank with the masking tape, and then trace the stencil onto the tank itself with the silver marker. This stencil is your cut line, and you'll be chopping this out and then welding in the new panels.
*******KEEP IN MIND THIS IS SOMETHING YOU WILL WANT TO TIG (GTAW) WELD!!! SO IF YOU CANNOT TIG WELD, MAKE PLANS TO TAKE IT TO A FRIEND WITH A SHOP CAUSE ANYTHING ELSE WILL LIKELY WARP YOUR TANK LIKE MAD!*******
EDIT: AFTER MEASURING THE STEEL USED FOR THE TANK I HAVE FOUND THAT I WAS INCORRECT IN MY ESTIMATE. THE STEEL IS ACTUALLY MUCH THINNER THAN I HAD ANTICIPATED. 20-22GA. TO BE EXACT. TIG WELDING WILL WARP THIS MATERIAL IF NOT DONE VERY CAREFULLY... SO I RECOMMEND MIG/WIRE FEED WELDING IT. USE A SMALL MACHINE (135ISH) AND 023 WIRE ON A LOW SETTING. THIS IS WHAT AUTO BODY TECHS ARE REQUIRED TO USE BY THE A.W.S. FOR CAR BODY SKINS. THANKS!
STEP 1:
First, you need to decide how far foward you want your tucks to be. Lay up a horizontal piece across the tank to give this mark. Second, use two long pieces to give you the marks for the upper/inner left and right tucks.
(If you aren't real good at proportions and eyeballing, you can measure this. Run a line down the centre of the tank, and measure out evenly. Dotted line this and tape it off.)
STEP 2:
Now that you have your main marks made, decide what angle you want the front leading cut on the knee dents to be at. I've made these vertical for now, but will mod them later as follows:
Here you can see this point from the top to give you an idea of the proportions. :)
STEP 4:
This is my favorite part. You need to take your paper and, resting against the marks with the tape, draw up your upper radius. Cut this out with your scissors.
STEP 5:
Now, take that paper and put it aside. Lay up 3 pieces of masking tape, and set the paper on there. Trace this radius onto the tape, and cut it out so that you have a radius of tape to apply to the tank.
Now, reverse that stencil onto another piece of 3 layered tape and do it again for the other side.
At this point you should have this on each side:
After this, it's a piece of cake. Whip out your awesome silver paint marker, and trace these stencils on the tank. :)
Piece of cake! :) You want to make sure you have a good paint marker for this. Make it something that's reflective (metallics) as they are easier to see while cutting later.
Here's a pic from the top.
Now, keep in mind how exactly you plan to deal with the base of the tank... you don't want to get this far, chop it and then realize you are gonna take out your petcock! :)
Measure and eyeball the hell out of this to make sure everything will work out for ya!
COMING SOON: PART TWO... CUTTING THE PANELS OUT.
Post edited by: twowheeledterror, at: 2005/12/20 02:27
Post edited by: twowheeledterror, at: 2005/12/22 21:06
Post edited by: twowheeledterror, at: 2006/01/20 16:51
  • dutchz
  • dutchz's Avatar
Re: Knee Dents in the stock tank... do it up.
19 Dec 2005 23:36
#13806
Sweet man... been thinking about doing this. I will keep a close eye on this post :blink:
1974 Kawasaki Z1
Stock front hub and rear axle.
  • letthegoodtimesroll
  • letthegoodtimesroll's Avatar
20 Dec 2005 08:26
#13819
Will you be making panels to go in or will you just swap sides with the pieces you cut out? If you switch sides it may give you close to the look!
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
  • cudaosix
  • cudaosix's Avatar
20 Dec 2005 09:19
#13822
Great post TwoWheel. I'm looking forward to your progress posts.
  • bkitchen
  • bkitchen's Avatar
20 Dec 2005 10:02
#13826
This is a very timely post...I just bought a tank off ebay yesterday to do this same thing!! $9.99 and just a few dents that are where I am going to cut anyway. I was trying to figure away around removing the petcock and keeping the back end of the tank the same so it would match my seat width.;)
  • fonZee
  • fonZee's Avatar
20 Dec 2005 11:40
#13830
Just out of curiousity, why would you do this ?
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
20 Dec 2005 12:53
#13838
So you wind up with something like this:
It gives you room for your knees, so you can tuck them in tighter. It's a cafe racer thing...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • twowheeledterror
20 Dec 2005 12:57
#13840
Because your tank as an expressive form of art is an awesome idea.
  • guitargeek
20 Dec 2005 14:10
#13849
FORM FOLLOWS FUNCTION! The art comes in when trying to acheive greater functionality by altering the form of an object. And yes, it is an awesome idea! ;)
  • ibsen22000
  • ibsen22000's Avatar
20 Dec 2005 15:53
#13852
The tanks used on the Norton and Kawasaki café racers you posted pictures of are specially made aluminium tanks, not stock tanks that are cut and welded.
Like this one:
www.w650shop.de/Cafe_Racer/cafe_racer.html
Also fiber tanks are common on cafe racers.
I don't think you can acchieve the same result with a stock steel tank without using a lot of filling and running the risk of the filling cracking up.
But I could be all wrong.
Btw, if you wan't to study art, take a look at these sites:
www.vd-classic.com/EN/realisation.php#
www.godet-motorcycles.com/egli/egli.htm
Post edited by: ibsen22000, at: 2005/12/20 18:54
  • twowheeledterror
20 Dec 2005 17:12
#13865
For starters, yes, the Kawasaki tank is a fabbed tank. It's actually a remake of a Norton short runner race tank.
Secondly, the Triton pictured is most definitely a modded tank. If you look at the edges of the knee indents they are rather sharp. You can't get that shape out of a tank without a cut and weld. The top portion is pounded, but the bottom was chopped and welded.
Thirdly, you most definitely CAN get the same appearance and look out of a modded tank. This is welding.. and pretty basic welding at that. Once you have the panels in place, you buildup overlayers so that you can then grind them and file them to smooth corners, assuming you want a polished tank.
If done correctly, you should't really need much filler at all to prep for paint.
And lastly, art is subjective. Those links you posted have nice bikes... but they aren't exactly exceptional. They all look just like the traditional style for cafe racers...
Post edited by: twowheeledterror, at: 2005/12/20 20:14
  • hwms
  • hwms's Avatar
20 Dec 2005 17:48
#13868
Ivar:
I thought the photo's were of Vincents.
Is the Vincent and Triton the same motorcyle ?
Harry
Post edited by: hwms, at: 2005/12/21 14:15
