Knee Dents in the stock tank... PHASE TWO CUTTING DONE!!!!
  • steell
  • steell's Avatar
Re: Knee Dents in the stock tank... do it up.
21 Jan 2006 07:48
#19054
Some posts have been deleted and others have been edited to remove references to the deleted posts.
Enough is enough. :angry:
If anyone wishes to complain, click the PM on the left or PM Stein or another mod. Do not post complaints here.
Post edited by: steell, at: 2006/01/21 11:26
  • fonZee
  • fonZee's Avatar
21 Jan 2006 08:54
#19066
You feel the Tig would generate to much heat ? What size gap are you filling ?
  • twowheeledterror
  • twowheeledterror's Avatar Topic Author
21 Jan 2006 09:52
#19079
TIG would apply too much concentrated heat.
The gaps are up to 1/8" at points.
023 wire feed is what is standard usage on all 20-22 ga body panels in the auto body industry as mandated by the American Welding Society.
The dissipation on this setup on steel produces the least amount of warpage.
TIG works GREAT on thin ALUMINUM because Al. has a much higher heat dissipation rate. :thumbup:
Post edited by: twowheeledterror, at: 2006/01/21 12:54
  • twowheeledterror
21 Jan 2006 09:53
#19081
If anyone wishes to complain, click the PM on the left or PM Stein or another mod. Do not post complaints here.<br><br>Post edited by: steell, at: 2006/01/21 11:26
Agreed.
Let's keep this thread about modding tanks! :)
If anyone has any other ideas or questions about ideas you've got please post em up!
  • fonZee
  • fonZee's Avatar
21 Jan 2006 14:21
#19124
And what guage is your tank?
  • mykznme
  • mykznme's Avatar
21 Jan 2006 15:28
#19137
you can keep the heat and warping down by not running a continuous bead and just spot welding all the way around it jumping from one side to the other
of course if your leaving your welds exposed it will look like crap
but if you plan on grinding them down thats the way i would do it
R.I.P. Odd Ivar
  • twowheeledterror
21 Jan 2006 21:26
#19181
20-22 depending on where in the contour you measure.
  • twowheeledterror
21 Jan 2006 21:28
#19182
Yeah and no. The problem is that the tank is steel. The welding method you are referring to is called stitching. It works great, and yes, it will help a bit... but the best way to avoid warpage is to simply use the right amount of amperage and the correct wire first and foremost.
035 is too thick to use efficiently.
And as I was saying, TIG is too much heat. To use effectively on this very easily.
  • mykznme
  • mykznme's Avatar
22 Jan 2006 04:36
#19213
just a thought, ive used it on body panels but never on a tank or anything as thick
R.I.P. Odd Ivar
  • twowheeledterror
22 Jan 2006 08:55
#19240
The tank is about as thick as body panels. :)
And you are defdinitely right, moving around and welding in stitches is definitely better than welding one solid bead.
