Aftermarket tail lights
- bountyhunter
Re: Aftermarket tail lights
18 Mar 2008 10:08
Draco wrote:
Not sure from the picture, but if the "dwarf base" is compatible with a standard 1157, the Luxeons just MIGHT fit into it. You can check their fabrication drawing for total height and see if you think it will fit. They would definitely brighten that sucker up. I think the heat would be OK, the LED's dissipate a lot less total heat than the standard and the Luxeons are monted to a heatsink that conducts the heat back to the base.
- Qdude
- It is all good.
21 Mar 2008 10:48 - 21 Mar 2008 10:48
I also think that from poor judgment comes learning, and from learning comes experience, and from experience comes wisdom.
So if wise men say less, it follows logically that older mouthy obnoxious fellows must show good judgment.
Thank you for the most excellent comparison on lamps. Very convincing experiments. I hear those LED lamps make great door stoppers.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 21 Mar 2008 10:48 by Qdude.
- OldSchoolHr
- Kawasaki z900a4 1976 Croatia, Europe
21 Mar 2008 11:37 - 21 Mar 2008 11:37
Klasmo bikes from Germany sell these aftermarket stop lights for old zeds with duck tail
and I think they are pretty cool.
link www.klasmo-bikes.de/land.php?auswahl=Art...=2&artikel_zaehler=1
My Gallery -
www.wix.com/limit2/z900
Last edit: 21 Mar 2008 11:37 by OldSchoolHr.
- Old Man Rock
23 Mar 2008 04:21
Klasmo Rear Tail light:
In reviewing the measurement of the Klasmo tail light width @ 200mm (7.874") and in comparing this to my KZ900 tail piece (6" wide at the most) this seems a weird fit.
For me, I think integrated LED is the way to go. Nice clean look with no need for side blinkers.
www.flyncycle.com/acatalog/Intergrated_led_tailLight.html
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Mark Wing
23 Mar 2008 11:30
Yorba Linda Cal.
Yorba Linda Cal.
- rstnick
23 Mar 2008 12:00 - 23 Mar 2008 12:05
That's what I've got as well, like Mark's above.
Fits the 650 tail nicely.
I'm using ZX turn signals for better visability.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 23 Mar 2008 12:05 by rstnick.
- Chopperdaddy
31 Mar 2008 14:48
OldSchoolHr wrote:
Any place to buy this in america ??? This is what i was looking for and knew someone had to make it . . .i put a similar on a softail for my dad one time
Into all things fast. . . Drag boats, bikes and cars . .. sucker for 50\'s thru 70\'s style also
- seanof30306
30 Apr 2008 00:44
Chopperdaddy wrote:
www.americanclassix.com/streetfighter_general.html
Third item from the bottom of the page
OldSchoolHr wrote:Klasmo bikes from Germany sell these aftermarket stop lights for old zeds with duck tail
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- twinkyrider
03 May 2008 06:06
I happened to come across an auto forum for hot rods discussing aftermarket taillights and brightness of bulbs. For those of you that have aftermarket taillights that will accept the standard 1157, Sylvania makes a 2357 LL(longlife) that has the standard 1157 running light filament but the brake(turn)filament is much brighter. I bought a set from Fleet Farm ($2.50 pr.)and the brake(turn) is quite a bit brighter. As a side note, my shakedown run a couple of weeks ago a filament did break probably do to vibration so I bought another set but this time GB oxgarded(dielectric grease) them (and carry a spare on board) and have had no problem since.(I also oxgarded all the bulbs of the tailights of my 03 Jetta a few years ago because of "issues" and haven't had to touch those bulbs since!)
I have twin cat eye tailights and made some reflectors from .040" aluminum for behind the bulbs to help direct the bulb light to shine "out" instead of getting lost in the housing. It did help. I can't help it sometimes I tinker too much, but I wanted brighter light out back, and I personally wouldn't touch those aftermarket cat eye turn signals that you can barely see. If only a co. would come up w/ some QUALITY mini turns for a few bucks more they'd be jumped on!
78 kz1000A
Fond du Lac,WI
Fond du Lac,WI
- MadKaw500
- yggy
- more wrenching than riding!
07 May 2008 13:16 - 07 May 2008 13:19
Hi here is the taillight from klasmo mounted to my z650...
cant get picasa to embed the pictures here it seems, so links will do for now:
picasaweb.google.com/vonyggystein/Z650/p...#5197730043772502210
picasaweb.google.com/vonyggystein/Z650/p...#5197730009412763826
picasaweb.google.com/vonyggystein/Z650/p...#5197729914923483266
well theres one picture then
1980 EU-z650 c4 one of the few C's around..
Last edit: 07 May 2008 13:19 by yggy. Reason: forgot that i could upload one to the kzforum :)
- chopkz750
09 May 2008 16:21
I was looking at the twin ness tailights or the dual maltese cross tailights. from here
www.flyncycle.com/acatalog/universal_rear_tail_lights.html
How much work do you thing it would be for the install?
