Aftermarket tail lights
  • Draco
  • Draco's Avatar
Re: Aftermarket tail lights
16 Mar 2007 07:03
#120656
Yup Toast, Looks like we both got the same crap product.
Live and Learn I guess.
  • ekawika
  • ekawika's Avatar
23 Mar 2007 22:51
#123008
Bilquetoast: A complete aside from the tail light issue, where'd you get those pipes???
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
24 Mar 2007 05:20
#123027
Whoa! Thread hijack alert!
They are stock Harley Sportster mufflers, mounted on standard KZ400 headers, with emgo adaptors (to change from 1 1/2 to 1 3/4 inch).
B)
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • Robjb84
  • Robjb84's Avatar
24 Mar 2007 05:39
#123030
Well I hooked up my lights and a) one of the bulbs was a milky colour and didnt work. Dead from the box :/ b) the bulbs were these silly little tiny things that I couldn't find anywhere!
Fortunately, normal tail/brake bulbs that are larger still fit in my assembly so overall, im not too bothered. Does the job for me and thats all I need :)
  • ekawika
  • ekawika's Avatar
24 Mar 2007 21:09
#123218
just had to comment on the pipes!
:unsure:
I actually put some of the plastic mini cat eye turn signals with the iridium lenses on the front of my 1979 kz400. I assumed they would come with amber bulbs. WRONG! I like the way they look, but the mini bulbs are impossible to get out to change to an amber bulb.
I only bought one pair to see how I like them. I was originally going to mount them on the back, but the threaded shaft is too short to fit through the rubber bushing that holds the stock turn signals.
I found this site that I think has a better selection than flyncycle.com
www.chromeandleatherplus.com/store/home.php?cat=317
they have aluminum parts rather than plastic, although some are obviously harley targeted.
AND
I was planning on ordering THIS tail-light with next weeks paycheck.
ewww.bellacorse.com/bcc091.htm
Post edited by: ekawika, at: 2007/03/25 00:12
  • Biquetoast
25 Mar 2007 04:56
#123253
ekawika wrote:
...I was planning on ordering THIS tail-light with next weeks paycheck.
Wow, that is nice.
But it looks like it's made specifically to mount on the Bonnie's rear fender. Doesn't look like I could use it. Looks like the lamp housing is plastic too, just the mount is aluminum. Still, it's very reasonably priced...
kz750twins.com
  • rpiian
  • rpiian's Avatar
  • Live to Ride, Ride to Live
05 Nov 2007 13:37
#179741
Wow these lights on Fly N' Cycle are just what I've been looking for. Has anybody tried the Twin Ness Universal Rear light? Looks like it has the best of both worlds with standard bulbs but a low profile...which is what I was going for. Should I go for it?
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
  • btchalice
  • btchalice's Avatar
14 Nov 2007 15:51
#181082
if its the style you want then always go for it
id like to see what the ness looks like on a 900 tail
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • rpiian
  • rpiian's Avatar
12 Mar 2008 17:05
#199801
Weeeeell that didn't work out as well as I hoped. I bought the Twin Ness taillight from flyncycle and I tried mounting the light underneath the frame. Bad news bears. As soon as I hit the street today (second day out this season by the way!) I hit a massive pot hole, bottomed out, and threw that beautiful -ness all over 15th street. Not a pretty sight and kind of a waste of money IMO. I went with a -94 zx6 ninja light today and hopefully (knock on wood) this is the last iteration I'll make on my taillight. I think I'm going to try making my own tail out of sheetmetal and put this zx6 taillight in line with the frame, not below it. Otherwise it's back to stock Big Bertha...Anyway, I was glad to be back on the bike while it lasted!
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
  • twinkyrider
  • twinkyrider's Avatar
15 Mar 2008 08:34
#200131
I got the same single cateye lights (bought singly because I didn't know they made the double) that allow for the standard 1157 (came w/ mini 1157). I mounted them both to one licence plate holder and plan to use them as turn signals also w/ a trailer wiring adapter. I turned the outsides of the two lights down to "conform" to my 78 kz1000A's duckbill instead of being straight across. Two odd things tho', I tested regular 1157's against the mini 1157's and the regular 1157's were no brighter than the minis. Also the lights came w/ a red, yellow and black wire, turns out the yellow is the ground??!!!
Does anyone have the spec sheet on double element auto bulbs that shows the wattage of each? 1157, 2057 etc.
78 kz1000A
Fond du Lac,WI
  • bountyhunter
  • bountyhunter's Avatar
18 Mar 2008 09:57
#200761
Draco wrote:
pyxen wrote:
One option is to get a 'cheap' aftermarket light, then LED bulbs.
You can get some LED bulbs that act as 'dual filament' bulbs do..that'd make 'em plenty bright. I grabbed a set of them from Wally-world to put in my stock tail light.
Do you happen to remember what they ended up costing you?
Happy with their performance?
The only drop in LED's that are actually brighter than a stock 1156 or 1157 incandescent buld are these 3W Luxeons:
www.superbrightleds.com/specs/115x-xLX3.htm
Looks like they are $24 now, I got mine back when they were $20. They are REALLY bright. I tried some of the cheaper LED tail lights and they were too dim to trust as brake lights.
  • bountyhunter
18 Mar 2008 10:00 - 18 Mar 2008 10:10
#200762
CoreyClough wrote:
You bet!!!
I look at it like a learning experience. Experience comes from poor judgement, and poor judgement comes from experience.
Onward I go.
Sounds like you won't be voting for Hillary...
Sorry, I couldn't resist....everywhere I look she is bragging about all of her "experience":laugh: Your quote looks like it should be her campaign slogan.
Last edit: 18 Mar 2008 10:10 by bountyhunter.
