4to6 inch over arm and 17x5.5 rim?
  • tw..
  • tw..'s Avatar
Re: 4to6 inch over arm and 17x5.5 rim?
25 Sep 2006 06:15
#79406
I'm running a 190 rear tire on a 5.5 rim and I have about a 1/8" - 1/4" clearance between the chain and rear tire.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • mikekz900
  • mikekz900's Avatar Topic Author
26 Sep 2006 06:32
#79690
I currently have a 180 tire on a 5.5 rim. I tried to do a 190/60 instead of a 190/55 but I just couldn't do either without cutting up the frame. SO I just went with a 180/55. I know that tires can vary quite a bit from manufacture, but some of the tires I was looking at I couldn't find anything. I eventually want to put a Shinko Stealth as this is the tire that all the drag racers use around here and I know it's a pretty sticky tire.
As far as a 6" rim when shopping for tires they all said 6 inches for a 200 and up and 5.5 for the 190 and down. I too like the idea of flatting out a tire for a bigger patch on the road (like a 190 on a 6 inch rim), but seating that bead is going to be a pain in the a$$.
  • tw..
  • tw..'s Avatar
26 Sep 2006 10:52
#79761
all i had to do to my frame was heat it with a torch and give a few good wacks with a large hammer to flatten the frame where the chain was rubbing. oh and grind the foot peg bolt that extended thru to the inside of my frame. I'm running a dunlop sportmax 208, 190/55. this setup works fine on my bike.
tw
2-1976 KZ900 A4
1978 Z1R
  • kawman1974
  • kawman1974's Avatar
26 Sep 2006 20:18
#79910
Everyone-
Thanks for the tips. Mike-Since I have a nickel frame, I think I am going to go the route you did (180/55) on a 5.5 rim with a Shinko Stealth tire.
Now I just need a rear disk hub to start the project!!!
Anyone familiar with any aftermarket brands that have the correct axle diameter for a 74Z1900?
Thanks,
Warren
  • wireman
  • wireman's Avatar
26 Sep 2006 23:30
#79939
ive still got the rear wheel i took off this bike.:whistle:
  • mikekz900
27 Sep 2006 08:30
#80000
Kawman1974, Nickel frame? What does that mean, but sounds nice I want one.... Is it just a color or is it nickel plated? Any pics?
mike
  • wireman
  • wireman's Avatar
27 Sep 2006 08:39
#80002
Post edited by: wireman, at: 2006/09/27 11:40
  • wireman
  • wireman's Avatar
27 Sep 2006 08:40
#80003
  • kawman1974
27 Sep 2006 15:51
#80101
Mike-
It is a nickel plated frame. I will try and attach a picture. Since this is the case, I do not want to beat on the frame at this point. I have some more pics if you have an e-mail address.
Thanks,
Warren
  • kawman1974
27 Sep 2006 15:51
#80102
Mike-
Thanks,
Warren
  • kawman1974
27 Sep 2006 17:31
#80122
Wireman-
Would you sell the caliper and disk with it? All I need is the hub. I am going to respoke it to a 17" aluminum rim. What price would you want? I am trying to get prices together right now. Thanks,
Warren
  • wireman
  • wireman's Avatar
27 Sep 2006 17:46
#80127
i gave the rotor to solomrus,but i have caliper somewhere let me do some digging ill let ya know;)
