Kawasaki 900 Z1 Project -Frame issue
- wireman
Re: Kawasaki 900 Z1 Project -Frame issue
15 Jul 2012 13:23I think that build date puts you right on the edge of still being a 74,what does the title say?K.D. HART wrote:Okay, I thought the 5 74 on the neck was the year it was made. Then it would be a 1975. I see now.peter1958 wrote: thats a 74 z1
Welcome to z-jungle!
- peter1958
15 Jul 2012 13:28
www.kzzone.com/
- K.D. HART
15 Jul 2012 14:14 - 15 Jul 2012 14:34wireman wrote:I think that build date puts you right on the edge of still being a 74,what does the title say?K.D. HART wrote:Okay, I thought the 5 74 on the neck was the year it was made. Then it would be a 1975. I see now.peter1958 wrote: thats a 74 z1
My friend is still cleaning out his dads house and hasn't found the title yet. His sister handled his dads paperwork and she is also looking for it. I think the other Z1 frame and motor has a date of 11 74, but the frame is stripped down and I see no chain oiler on it.
Thanks for the welcome!
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
Last edit: 15 Jul 2012 14:34 by K.D. HART.
- K.D. HART
15 Jul 2012 14:28 - 15 Jul 2012 14:35peter1958 wrote: kzrider.com/forum/11-projects/216290-omr...nmodification#217213
Thank you sir!
I like this link. I guess I have a lot of reading to do. I even like these street fighter bikes you guys have made, but the triple trees look custom. I also like these mono shock setups. Like I said before. I have a lot of reading to do before I start buying or cutting. I assume there are vendors here that can make or mod triple trees, if I go that route?
Last edit: 15 Jul 2012 14:35 by K.D. HART.
- Kidkawie
- I bleed premix
15 Jul 2012 17:22
If you post the frame and engine numbers myself, or someone from Z1 owners club can determine the year. If you hack up a Z1, at least sell the original parts so someone else can restore theirs.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- K.D. HART
15 Jul 2012 22:55 - 15 Jul 2012 22:56Kidkawie wrote: If you post the frame and engine numbers myself, or someone from Z1 owners club can determine the year. If you hack up a Z1, at least sell the original parts so someone else can restore theirs.
I may just do my mods to the frame and engine I dug up out of the weeds then and keep the whole bike for a restoration at a later time.
Okay, I went out in the shed to get these serial numbers.
The whole bike numbers are:
Frame Z1F-45780
Engine Z1E 045808
Frame and Engine numbers are:
Frame Z1F-64252
Engine Z1E 064368
Last edit: 15 Jul 2012 22:56 by K.D. HART.
- K.D. HART
15 Jul 2012 23:38
Thanks for the help.
It looks like the bike is a 1974 and the frame w/engine is a 1975
16 Jul 2012 12:49
a couple projects with some mods as well,
kzrider.com/forum/11-projects/478810-thr...r-to-ride-til-winter
a stem swap can adapt any frontend you choose(within reason)to your bike.
as long as you dont cut the frame up you can always return it to stock if you desire.
- K.D. HART
16 Jul 2012 13:05 - 16 Jul 2012 13:09531blackbanshee wrote: a couple projects with some mods as well,
Ahh, you guys are swaping stems. I wondered how you put different front ends on these bikes. Swingarms I understand more, except for the monoshock setups, but I'll learn. Helped a buddy with his Z1 drag bike back in the early 90's. Extended the swingarm and lowered it. Man was that thing fast!
I've been thinking of buying this bike to drive for now, but concerned about the fouling plug on one cylender. Could this be more than a carb issue?
peoria.craigslist.org/mcy/3095687971.html
Last edit: 16 Jul 2012 13:09 by K.D. HART.
- wireman
16 Jul 2012 13:12
Id buy that if I knew for sure it had the 1170 kit in it and it had decent compression.
- K.D. HART
16 Jul 2012 14:23wireman wrote: Id buy that if I knew for sure it had the 1170 kit in it and it had decent compression.
That's the thing? I'm wondering if that cylender that fouls plugs might have a ring problem?
I think my dad has a comprssion gauge in the shop somewhere? Any ideas what compression should be? I know enough to take readings on more than just the one jug to give me an average, but any ideas to give me a ballpark figure on what the compession should be with this big bore kit?
