Welcome,
Guest
Hey all,
Since I didn't really nowhere to place this posting in the forum, I figured this is a good as place as any. As can be reviewed in the next two postings (only 1 image at a time Constructive criticism welcome.... Old Man Rock |
1976 KZ900-A4
MTC 1075cc. Camshafts: Kawi GPZ-1100 .375 lift Head: P&P via Larry Cavanaugh ZX636 suspension Keihin, 29mm CR specials Kerker 4-1, 1.5" comp baffle. Dyna-S E.I. Earls 10 row Oil Cooler Acewell 2802 Series Speedo/Tach Innovate LC1 Wideband 02 AFR meter Phoenix, Az
The administrator has disabled public write access.
Swing Arm Image set 2....
BTW... This is not chrome boys & girls but Buffed Aluminum... Old Man Rock |
1976 KZ900-A4
Last Edit: 4 years 11 months ago by Old Man Rock.
Forgot... Paint Job on Tank...
1976 KZ900-A4
I recently got a gs1100 swingarm to put on my '77 1000. It needs a good cleaning and I would love to end up with it looking close to as nice as yours. Please explain what you did to get it to look that good
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider 1979 KZ 1000 LTD - Parts bike and/or future project 1979 KZ 1000 ST 1980 GS 750 L 2003 ZRX 1200 R
lots of block sanding followed by lots of rubbing and buffingB)
coming soon zee-1 lawn service and pet stuff disposal services enterprises.tm/inc/pat pending
Looking good! I'm starting to rethink my 2 year project and get it back together.
Rathdrum Idaho
1971 Kawasaki g3ss 1972 Yamaha R5 350 1965 Suzuki Hillbilly 1964 Yamaha 125
kztee,
As Plummen wrote, patience and time is required. It took me roughly 2-3 days worth of work to strip the arm of factory black paint then sanding and buffing. The trick is.... Apply your compound for 1 second only on your drill buff wheel while spinning. Don't apply too much at one time for it defeats what your trying to accomplish. Then apply to your part for buffing. Don't work in just one spot, move it around as you would if sanding for example. The buffing wheel will go black in color as expected for your actually cutting the surface. Once you see that your not really cutting any longer, apply again your compound for 1 second and repeat. For deep scratches sand down with 80 grit sand paper, then work your way up to 1000 grit to 2000 grit. For light surface scratches then buffing with Tripoli (medium cutting) should work just fine. Then using a buff wheel on a drill (available at Lowes or Home Depot), buff with Tripoli to remove medium depth scratches and finish off with white compound (light cutting) for Bling! Use the forum search key "Aluminum Buffing"... There's a lot of these guys that already have it figured out and have provided the answers for some truly beautiful work. And by all means, post some images once finished and a write up of what you did, share the wealth of knowledge. Old Man Rock |
1976 KZ900-A4
oh yes good job omr.now post soem more of them pictures that you have been keeping from us
1976 kz 900 x 3 i make what i can,and save the rest! billybiltit.blogspot.com/ www.kzrider.com/forum/5-chassis/325862-triple-tree-custom-work
I like your paint colors. I have been considering a similar combo with red and silver accent striping.
Nice work on the shock mount! Looking good.
When I stop drooling I will get back to you on all of that. lol Love the paint and thanks for the 1 second tip. I just finished buffing my stuff and was holding the compound for at least a couple of seconds. Now I know. I started with the sand paper to remove all of the casting marks, etc. Lot of work that came out to be but I am glad because it was well worth it. I went black emory to the tripoli and then white but man those little scratches take a long time to get out! Don't hold back with the pics.
Pretty soon here I will have some time off and will do the same to my ride. |
79 LTD B3
Back to life! Stock, Dyna ign., coils, taylor wires, 29 smootbore, V&H pipe 80 LTD B4 1075 kit JE Pistons .410 cam grind, Vance and Hines with Comp Baffle, 31 keihin cr's, K&N pods, Dyna coils and ignition, Taylor Wires. EPE swingarm 2" over with custom rotor and caliper (in the process
Maybe this will help...
Caswell tutorial/guidance explains the compounds and buffing wheels to use. http://members.cox.net/ruinsofstei/Buffbook.pdf Remember, Use little (compound) and use often is the key;) Now onto buffing my rims... Old Man Rock |
1976 KZ900-A4
Rear Rim... Cleaned, Buffed and Installed....
(NOTE: Next 3 postings for images) Old Man Rock |
1976 KZ900-A4
Buffed Rim 2....
1976 KZ900-A4
Buffed Rim 3....
1) Cleaned and Taped off. 2) Fiber Wheel from ACE Hardware... Clean off factory rim paint. 3) Start with 120 sand paper to 800 grit. 4) Buff with Emory, then Tripoli then finish with white. Onto front Rim... Old Man Rock |
1976 KZ900-A4
I love your work and pics. I am so looking forward to seeing this one together.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s. 83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
Very nice!
I'm planning on polishing the lips on my wheels too,whenever I DO get to my conversion. That looks sweet! |
1977 KZ1000 A-1
Joe,
Well, I had a peek at the project and it looks GREAT! You're a stickler for details and I love it! The paint was everything you said it was. I'm going to scope some out shortly. Keep up the good work. Holler when you're ready to ship the stuff for mods..... Larry C |
1976 KZ900-A4
1976 KZ900-A4
