KZ1000 Brake Upgrade?
  • otakar
  • otakar's Avatar
Re: KZ1000 Brake Upgrade?
06 Jun 2011 00:54
#455717
I have a set of those calipers also. They are dual piston and harder to adapt than the Tokico ones. That is why I finally chose the previous ones.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Ktm181
  • Ktm181's Avatar
  • Man made it, so Man can fix it
08 Jun 2011 20:40
#456199
Hey Harvey, how does it stop with these? What size mastercylinder are you using? did you run into any spoke clearance problems???
Thanks mate, interesting info in this thread, I have been chasing a setup like this for a little while down in Australia, looks very neat and tiday, WELL DONE!
kT
  • fxdl2051
  • fxdl2051's Avatar
31 Jul 2011 04:52
#465968
mjg15 wrote: MKII,
IIRC, I probably cleaned them with scotchbrite. Sodablasting works well too, but I didn't have one when I did those wheels/rotors last year.
Scothbrite? I know this sounds silly, but I've never tried this before. How do you do this?
Thanks,
Ken
  • otakar
  • otakar's Avatar
31 Jul 2011 10:05 - 31 Jul 2011 10:07
#465987
Scotchbrite @ Is a scowering pad made out of plastic and impregnated with abrasive. They come in different colors which determine the grit. Most common are green and red. I believe they are even available fro Harbor Freight. It is kin to using steel wool or sand paper but more effective. I buy mine at McMaster-Carr because they have a selection of grits.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Jul 2011 10:07 by otakar.
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
31 Jul 2011 11:30 - 31 Jul 2011 11:32
#466002
I have ordered some from McMaster Carr myself, but also found some recently at home depot:
www.homedepot.com/Scotch-Brite/h_d1/N-5y...0051&catalogId=10053
The Kaw List:
Last edit: 31 Jul 2011 11:32 by 79MKII.
  • boyracer
  • boyracer's Avatar
31 Jul 2011 11:33
#466003
mjg15 wrote: 1000 Police forks/calipers with KZ1300 18x2.15" wheel and 298mm rotors, all stock Kaw parts w/no machining,on a 550. It should stop well
These look the similar to my set up. I have z900 spoke wheel hub, Z1R discs and floating calipers off a gpz900r. made the mounts with hacksaw and files out of alloy plate.The braided lines improve the spec no end!
Attachment S5000977.JPG not found
Attachment S5000983_2011-07-31.JPG not found
  • otakar
  • otakar's Avatar
31 Jul 2011 11:37
#466004
That is a very good price at Home Depot MUCH cheaper than McMaster. I also love to use these to final polish my ports after I do a Port job.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
31 Jul 2011 11:40
#466005
These are mine Gun-Koted @
Attachment DSC01006.JPG not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
31 Jul 2011 11:41
#466006
Here are some other Gun-Koted @ components.
Attachment DSC00963.JPG not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
31 Jul 2011 11:43 - 31 Jul 2011 11:45
#466007
Why do you have the calipers Up-Side-Down? How do you bleed them properly?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Jul 2011 11:45 by otakar.
  • boyracer
  • boyracer's Avatar
31 Jul 2011 11:57
#466009
I live in Australia....Downunder?
The photos are from when i first picked up wreck..lightly assembled from a basketcase. I can't say i remember how i first built 'em up...will check for old photos.
  • grubdog
  • grubdog's Avatar
09 Aug 2011 10:30
#467974
I would like to have a back-up set of brakes for my 79 KZ. It would make sense to upgrade to ZX 7 brakes. What year are those calipers?
