GPZ 750 wiring
- F64
- 81-KZ440D2
Re: GPZ 750 wiring
01 Oct 2026 20:58 - 01 Oct 2026 23:49
What makes you think you have weak spark?
Did you use an adjustable spark gap tester?
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 01 Oct 2026 23:49 by F64.
Re: GPZ 750 wiring
02 Oct 2026 09:22
Also, I'd say that a voltage drop from 12.0 to 7.5 is indicative of a weak battery.
Re: GPZ 750 wiring
02 Oct 2026 09:55
Anything much lower than 9.5v cranking suggests a weak battery or resistance (possibly bad ground on the motor?
- notgoodwithnames
Re: GPZ 750 wiring
02 Oct 2026 13:45
I'll check for grounds but it's a brand new fully charged battery so unless something is strangely wrong with it then it shouldn't be that
1983 GPZ 750
- notgoodwithnames
Re: GPZ 750 wiring
02 Oct 2026 15:22
Just for posterity I went and completely sanded off the ground at the ignition coil, the right back side of the motor, and the one at the starter solenoid but I'm still dropping to 8.5v on crank
1983 GPZ 750
Re: GPZ 750 wiring
02 Oct 2026 16:20
A new battery can be bad. If you connect your meter to the battery posts, not the cables, and then turn on the key and press the starter button, the initial reading before turning anything on should be at least 12.5 and should not drop below 10 or 10.5 with the starter engaged.
Re: GPZ 750 wiring
02 Oct 2026 16:47
Where are you getting the 8.5v reading
- notgoodwithnames
Re: GPZ 750 wiring
02 Oct 2026 16:52
At the wires going into the ignition coils
I pulled the battery out of my daily riding motorcycle and got the same result, low voltage at the coils
1983 GPZ 750
- F64
- 81-KZ440D2
Re: GPZ 750 wiring
02 Oct 2026 18:35
Grab your voltmeter
DC V
Key ON
Kill Switch set to "RUN"
Engine running
red probe on positive battery post
Black probe on red wire at one coil
what is your voltage?
voltage should be as close to 0.0V as possible
any higher than 0.5V is too much resistance
move black probe to the other coil's red wire
what is the voltage?
move red probe to negative battery post
black probe to a bare metal part of the engine
should be close to 0.0V as well
DC V
Key ON
Engine running
81-KZ440-D2.
LIC, NY
LIC, NY
- notgoodwithnames
Re: GPZ 750 wiring
02 Oct 2026 19:00Key on I have .252 between the positive post and both red wires, 0 between the negative post and engine ground, I assume you meant this state not with the engine actively running, if I need to hit the starter it'll have to wait till morning tomorrow as it's a bit too late in the house for the ruckusGrab your voltmeter
DC V
Key ON
Engine running
1983 GPZ 750
- F64
- 81-KZ440D2
Re: GPZ 750 wiring
02 Oct 2026 20:43 - 02 Oct 2026 20:56
The ground measurement needs to have the bike on but it doesn't have to be running, but current needs to flowing to something(like a headlight).
So you should redo the ground reading tomorrow morning with key on, kill switch "run", engine running.
no need to wake the neighborhood tonight.
The coil measurements needed a running bike because I wasn't sure if the igniter or junction box would cut power to the coils if the bike wasn't running.
Your red coil wires are ok resistance wise. not great, but your bike should run ok.
I am, like the others above, curious about your battery's condition.
tomorrow morning
meter on DC V
key on
kill switch"on"
engine not running
red probe on the positive battery post
black probe on negative battery post
hit the starter button
what voltage does the battery drop to while the starter button is pushed?
what is the voltage at the battery when the bike is idling?
what is the voltage at 3000 rpm?
turn bike off
tomorrow morning
meter on DC V
key on
kill switch"on"
engine not running
turn bike off
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 02 Oct 2026 20:56 by F64.
- notgoodwithnames
Re: GPZ 750 wiring
02 Oct 2026 21:06
The bike isn't generating enough spark to have any audible ignition let alone get it idling or have it run up to 3000rpm
I'll give the ones I can a shot come sun up
1983 GPZ 750
