GPZ 750 wiring
  • notgoodwithnames
  • notgoodwithnames's Avatar Topic Author
Re: GPZ 750 wiring
28 Sep 2026 18:20
#928007
put your red probe on the black wire that has none and push the starter button..
voltage?
Still none
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:22
#928008
your switch is bad
take a small wire and jumper both black wires
does the starter turn?
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: notgoodwithnames
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 18:25
#928009
your switch is bad
It sure as shit did, what a great end to a 9 hour headache. I'm sure it's gonna be an absolute bitch finding an original replacement
1983 GPZ 750
The following user(s) said Thank You: F64
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:26
#928010
your switch may just be pitted.. you might be able to clean it
81-KZ440-D2.
LIC, NY
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 18:29
#928011
When I get home from work tomorrow I'll disassemble it and hit it with a wire wheel. It looked pretty clean and worked not but a few months ago, but I did have one of the solder connections fail and I redid it so maybe I fucked something up when I did that. I'll hopefully have a post by this weekend with it riding, I bought the bike in May with the intention to ride it up to Barber this year so real crunch time goin on right now
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:41
#928012
Well, what's good is that you know the issue.
Let us know what you find when you get the switch apart.
81-KZ440-D2.
LIC, NY
  • H1Vindicator
  • H1Vindicator's Avatar
Re: GPZ 750 wiring
30 Sep 2026 06:23 - 30 Sep 2026 06:24
#928059
.. the Clymer manual states ...
just in case. there are a couple of 750-4 fsm pdfs floating around the internet. should be linked here on KZR. one has a yellowish cover with color wiring diagrams. the other is black-&-white.
Last edit: 30 Sep 2026 06:24 by H1Vindicator.
  • notgoodwithnames
Re: GPZ 750 wiring
01 Oct 2026 14:48 - 01 Oct 2026 15:24
#928100
Well everything is together and I went to go start the bike just now, really weak spark I thought it was the ignition coils but now I'm suspecting the igniter box. Any advice on replacements?
1983 GPZ 750
Last edit: 01 Oct 2026 15:24 by notgoodwithnames.
  • bound
  • bound's Avatar
  • If you ain't HURTIN' you ain't LEARNIN'!!
Re: GPZ 750 wiring
01 Oct 2026 17:31
#928104
Did you actually test the ignition coils to be sure that they aren't the problem? It could also be your spark plugs or caps. I wouldnt go assuming its the igniter until you've gotten all of the more susceptible items out of the way. Do you have good voltage going to your coils? If you have a service manual it has nice testing procedures for this that I would check out.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • notgoodwithnames
Re: GPZ 750 wiring
01 Oct 2026 17:49
#928106
Ignition coils have 12v at key on and drops to 7.5-8 when hitting start, both ohm out at 2.4, 470 out of the pickup coil. I went through all the tests in the Clymer manual and the only thing I haven't done which it recommends is to try a known good igniter
1983 GPZ 750
  • bound
  • bound's Avatar
Re: GPZ 750 wiring
01 Oct 2026 19:13
#928109
I prefer factory manuals if possible. Here is how to test the igniter if you wish.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • notgoodwithnames
Re: GPZ 750 wiring
01 Oct 2026 19:48
#928111
I'm getting ohm readings that seem to be way off from everything in that chart. The 4 and 5 pin which it says should have infinite with everything also has resistance with multiple other pins. I found another one local that I'm gonna pick up tomorrow morning so fingers crossed I get to actually ride the damn thing for once instead of using it as decor
1983 GPZ 750
