GPZ 750 wiring
  • notgoodwithnames
  • notgoodwithnames's Avatar Topic Author
Re: GPZ 750 wiring
28 Sep 2026 17:33
#927995
meter the g/w wire at the junction box.
put your volt meter on DC V.
black probe on the G/W wire.
red probe on the positive battery post.
what is your voltage?
12v
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 17:40
#927996
ok, so the side stand switch is disabled.
meter the starter solenoid.
key on
kill switch "run"
meter on DC V
black probe on negative battery post
red probe on yellow/red wire at starter relay
push starter button.. what is you voltage?
81-KZ440-D2.
LIC, NY
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 17:45
#927997
key on
kill switch "run"
meter on DC V
Effectively nothing
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 17:50 - 28 Sep 2026 17:53
#927998
ok.. you aren't getting +12v to the solenoid.
move the red probe to the yellow/red wire at the junction box
black probe still on negative battery post
press the start button
81-KZ440-D2.
LIC, NY
Last edit: 28 Sep 2026 17:53 by F64.
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 17:57 - 28 Sep 2026 17:59
#927999
Continuity, no power
I ohmed out the starter relay earlier, 70 ohms on the non broken side, also tried swapping head and start since my start one has corrosion on the outside
1983 GPZ 750
Last edit: 28 Sep 2026 17:59 by notgoodwithnames.
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 17:59
#928000
move the red probe to the black wire next to the yellow/red on the juction box
voltage??
81-KZ440-D2.
LIC, NY
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 18:01
#928001
voltage??
None
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:05 - 28 Sep 2026 18:06
#928002
ok, your starter button is not sending +12v to the junction box.
find the connector for your starter switch/kill switch..
put your red probe on each of these 4 wires with the
key set to "on"
kill switch set to "run"
do not disconnect the connector
what are your voltages?
81-KZ440-D2.
LIC, NY
Last edit: 28 Sep 2026 18:06 by F64.
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 18:09
#928003
key set to "on"
I had the starter open earlier to check the connections, 12v on both reds, continuity between all 4 wires
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:10 - 28 Sep 2026 18:11
#928004
what about the black wires?
i need the voltages on those
81-KZ440-D2.
LIC, NY
Last edit: 28 Sep 2026 18:11 by F64.
  • notgoodwithnames
Re: GPZ 750 wiring
28 Sep 2026 18:15
#928005
Black that is soldered behind the spring has 12v when put to ground, the one on top of run switch has none
1983 GPZ 750
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: GPZ 750 wiring
28 Sep 2026 18:17
#928006
put your red probe on the black wire that has none and push the starter button..
voltage?
81-KZ440-D2.
LIC, NY
