Intermittent spark
- F64
- 81-KZ440D2
Re: Intermittent spark
18 Jun 2026 03:30
From an older 550 service manual.
diode bank should be the same as the wire colors are the same.
His service manual should have the procedure for checking the diodes
81-KZ440-D2.
LIC, NY
LIC, NY
- F64
- 81-KZ440D2
18 Jun 2026 04:51 - 18 Jun 2026 05:24
So Svanslos,
You will have to locate the diode pack.
My guess it will be close to the igniter
6 wire connector
3 brown/white wires
1 light green wire
1 yellow/green wire
1 brown wire
disconnect the connector to the diode pack
set your meter to resistance
on the diode pack
you will place your red probe on the first brown/white terminal and black probe on the yellow/green terminal
what is the resistance?
reverse your probes--black probe on that brown/white terminal and red probe on the yellow/green teminial
what is your resistance?
next
move your probes to the next terminals over.
red probe on the brown/white terminal in the middle slot
black probe on the brown terminal
reverse your probes
red probe on brown
black probe on brown/white
move your probes over to the last slot
red probe on brown/white
black probe on light green
reverse the probes
red probe on light green terminal
so your two readings with each slot should be different when the probes are reversed.
the two readings should never be the same.
there should be at least a difference of 10x between the two readings.
one direction maybe 10 ohms
reversed should be at least 100 ohms
if the readings are the same, you have a bad diode inside.
there are 3 diodes inside that diode pack.
6 wire connector
3 brown/white wires
1 light green wire
1 yellow/green wire
1 brown wire
on the diode pack
next
reverse your probes
red probe on brown
reverse the probes
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 18 Jun 2026 05:24 by F64.
- SvansLös
18 Jun 2026 05:56
Thanks for fantastic advice, just left the workshop to celebrate midsummer, will be back Monday with my spirit high and test the diodepack! Update will surely follow
- jwfels
18 Jun 2026 09:25
H using this system on 74 900 and a 81 650, please search retrofit ignitions, the diodes are a fancy way of tying all the starter interlocks together to provide 12- to the igniter, info on old post was obtained from classik forum, proof the diodes? ground out the black/yellow and the Br?/w, (other diagram show it as a black/ white, in the diode plug, the feed 12- to ignitor, see if it runs, wold put up a link, don’t know on ipad thx
Z1A AND 81 650
18 Jun 2026 09:37
Thanks Jewels I think we have established the ground is missing on the black/whitw
- SvansLös
21 Jun 2026 23:19 - 21 Jun 2026 23:47
Good morning! I get a reading on the diodes with the multimeter set to the "diode" option. One way on all three diodes it read about 620, reverse the probes and it read "I". Multimeter set to resistance on the 200k range i get a reading of about 160 on all three diodes and "I" if i reverse the probes. This is when the bike has not been running, will try again when i have hadr the chance to run it.
Last edit: 21 Jun 2026 23:47 by SvansLös. Reason: Wrong info
22 Jun 2026 00:34
Once you have had chance to run it, if/when the fault occurs try fitting the bridging wire I mentioned between the black/yellow and brown/white at the igniter
- SvansLös
22 Jun 2026 02:45
Fault occured, The diodepack reads the same, and no difference with the bridging wire between black/yellow and white/brown
22 Jun 2026 03:31 - 22 Jun 2026 03:40OK so bridging the brown/white with black/yellow by-passes the side stand switch, clutch swich and neutral light switchFault occured, The diodepack reads the same, and no difference with the bridging wire between black/yellow and white/brown do you mean still no spark ?
Battery voltage on the green and black at the igniter confirms coil circuit ok (feed to coils, coils and wires to igniter from coils)
Did you check for battery voltage at the yellow/red on the igniter ? if yes that only leaves the pick-up coils or the igniter - have you carried out the checks in the manual for the pick up coils at the igniter plug ? (this will check the wiring as well as the pick-ups)
Last edit: 22 Jun 2026 03:40 by Wookie58.
- F64
- 81-KZ440D2
22 Jun 2026 03:35
Take a can of air, turn it upside down and spray the igniter to freeze it when the bike dies. You may have an igniter that fails when it gets hot.
Don't spray it when the bike is running.. it's slightly flammable as a vapor.
81-KZ440-D2.
LIC, NY
LIC, NY
- SvansLös
22 Jun 2026 04:43
I have measured resistance in the 4-pin connector for the pickupcoils, with multimeter set to the 2k range it reads .450 on both with or without spark. There is a test table for resistance on the male ignition coil connector aswell, which connector would that be?
22 Jun 2026 04:50Have you also measured the resistance for the pick up coils at the 10 pin plug for the igniter (with the igniter disconnected) ? this checks the wiring between the 4 pin and 10 pin plugs. Can you post the test able you are referring to for the ign coil connector (I don't have sight of a manual for your bike)I have measured resistance in the 4-pin connector for the pickupcoils, with multimeter set to the 2k range it reads .450 on both with or without spark. There is a test table for resistance on the male ignition coil connector aswell, which connector would that be?
