Intermittent spark
- Bloobaba
Re: Intermittent spark
17 Jun 2026 22:18
Hello. Why replace the Kawasaki variable advance ignition with a Dynatek? Is the original one faulty? Be aware that there are several models of centrifugal advance cams depending on the motorcycle. I'm currently working on a programmable advance system with original sensors and 4-pin HEI modules. The heart of the system is an Arduino Nano with a small 0.96-inch screen and an HTML interface. HEI modules have the advantage of being inexpensive.
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
- SvansLös
17 Jun 2026 22:29
Hi
Im having triuble with intermittent spark amd i am suspecting it is either the pickups or the ic igniter. If i can replase both these parts with a dynatrk it seems a done deal. My particular bike has electronic timing advance in the igniter but the gt550 came with mechanical advancers aswell and i was thinking it would be possible place a mechanical advancer in my bike.
- Bloobaba
17 Jun 2026 22:51
Start by checking the ignition coils. Although they respond well to resistance measurements, sometimes they can be faulty. I had a problem with a coil on my GPZ900. It ran well above 2500 rpm and poorly below. Original CDI systems are generally very reliable. Sensors like the one I photographed can be replaced and aren't very expensive. I think all GT550s had centrifugal advance ignition. Be aware that the sensors are different. Mixing components isn't a good idea because the time it takes for the cam to pass the sensor is longer for electronic advance systems. You might have an advance curve that's not well-suited to the GT550. The CDIs were fitted from the ZX, which have completely different characteristics.
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
17 Jun 2026 23:52
Telma I have merged your two threads (please try to keep to one thread per issue) you are getting advice for the same issue on two different threads which will become confusing for you to keep track of and frustrating for anyone trying to help you.
I would suggest you complete the advised test steps before changing anything. Throwing parts and money at a problem is not diagnosis !!!
As your bike is a much later model (this fact missed me initially) do you have a wiring diagram for your specific model ?
Does your bike have an ignition cut out switch on the side stand ?
18 Jun 2026 00:13I don't want to be pedantic but for clarity these bikes don't run "CDI" but more like "TCI" - True CDI has a constant ground to the coils and at the appropriate time a capacitor in the ignition module discharges a momentary pulse of between 250 and 600v (only measurable with an oscilloscope) into the coil primary. These systems generally run very low resistance coils (typically 0.3.-0.5ohms)Start by checking the ignition coils. Although they respond well to resistance measurements, sometimes they can be faulty. I had a problem with a coil on my GPZ900. It ran well above 2500 rpm and poorly below. Original CDI systems are generally very reliable. Sensors like the one I photographed can be replaced and aren't very expensive. I think all GT550s had centrifugal advance ignition. Be aware that the sensors are different. Mixing components isn't a good idea because the time it takes for the cam to pass the sensor is longer for electronic advance systems. You might have an advance curve that's not well-suited to the GT550. The CDIs were fitted from the ZX, which have completely different characteristics.
- SvansLös
18 Jun 2026 01:05
I have checked both primary and secondary windings, i have continuity on all mounting posts. I also have another set of coils that give me the same problem.
- SvansLös
18 Jun 2026 01:15 - 18 Jun 2026 01:18
Everything is stock except HT leads, and stator, i had no resistance between two of the wires, the bike is charging when its running.
Battery voltage is around 12.2
Voltage yellow/black wire att ic connector is 0.00
Battery negative to engine block also 0
Battery negative to green trigger wire and black trigger wire is the same as battery voltage
Batttery positive to to red/yellow wire at ic connector is 12v
Battery positive to red/yellow wire to coils is 0.05
This is all with everything being connected.
Last edit: 18 Jun 2026 01:18 by SvansLös. Reason: Layout
- SvansLös
18 Jun 2026 01:22
Sorry, thank you
previous owner removed side stand switch, i connected the wires so that the circuit is always closed.
18 Jun 2026 01:27Please clarify - are you saying that you have continuity between the primary or secondary windings and the mounting post ?I have checked both primary and secondary windings, i have continuity on all mounting posts. I also have another set of coils that give me the same problem.
What is the resistance of the primary windings ?
What is the resistance of the secondary windings ?
- SvansLös
18 Jun 2026 01:34
I dont really understan what you want me to measure with the mounting posts sorry,
primary resistance is 2.8 and 3.1
secondary on both ~12k
18 Jun 2026 01:48I dont really understan what you want me to measure with the mounting posts sorry, - see below (don't worry your English is way better than my Swedish)
primary resistance is 2.8 and 3.1 - Good
secondary on both ~12k - Good
- F64
- 81-KZ440D2
18 Jun 2026 01:53 - 18 Jun 2026 02:08Everything is stock except HT leads, and stator, i had no resistance between two of the wires, the bike is charging when its running.
your igniter is not getting +12v
measure that connection again
key on
kill switch to run
black probe on battery positive
red probe on yellow/red wire
back probe both sides of the connector for the yellow/red wire
reading should be 0.0v not 12.0v
turn the key off
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 18 Jun 2026 02:08 by F64.
