Intermittent spark
  • SvansLös
  • SvansLös's Avatar Topic Author
Re: Intermittent spark
22 Jun 2026 05:29
#925162
Resistance in 10-pin connector is the same,
  • SvansLös
22 Jun 2026 09:56
#925177
Ok so to circle back, can you fit a mechanical advancer on a bike that does not originally have one and then install a knock-off dynatek kit? Try my luck with Ebay and pre-owned? I have also seen that you can send your unit to carmo electronics and then they diagnose and repair your units, anyone tried this?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
22 Jun 2026 11:38
#925179
If you want to go the dyna s route you need to look in the manual for your bike and the donor then compare the advance curves
  • rangeroy
  • rangeroy's Avatar
23 Jun 2026 01:10 - 23 Jun 2026 01:13
#925207
you could do worse than look here
index Lou D's Motorcycle Stuff
also lou's legacy posts are full of electrical knowledge, it maybe just a darlington chip thats gone southbound in the ic igniter box cost around £2 each from Farnells or RC components.
good luck & what about this companys products?   Electronic for motorbikes - IgniTech Přelouč
1977 z650
Last edit: 23 Jun 2026 01:13 by rangeroy. Reason: adding info
  • SvansLös
13 Jul 2026 10:05
#925737
Hello all, here is a small update, i bought an igniter unit from Ignitech, courtesy of Rangeroy, and have not encountered the no spark problem ever since, huge win! Now, on to the problems i had not hade the chance to encounter yet.
Thank you all for your help!
//Telma
The following user(s) said Thank You: rangeroy, Wookie58
