Intermittent spark
- SvansLös
- SvansLös
Re: Intermittent spark
18 Jun 2026 02:20
Maybe i was to quick, my bike does not have that 4 pin connector, if i put the probe in the 10pin connector yellow/red wire to the igniter i get 0.07v
18 Jun 2026 02:27
If you unplug the igniter then put the black meter lead in the Black/yellow and the red first in green then black with the ignition on do you get battery voltage on both green and black - if yes move the black meter lead to the black/white do you get the same results on the black and green
18 Jun 2026 02:31That diagram is for the earlier ignition with "mechanical" advancerMaybe i was to quick, my bike does not have that 4 pin connector, if i put the probe in the 10pin connector yellow/red wire to the igniter i get 0.07v
- SvansLös
18 Jun 2026 02:41
About 12v black/yellow to green and black
black/white to green and black ~0.01
18 Jun 2026 02:53 - 18 Jun 2026 02:56Black/white needs to see ground through the neutral light or clutch switch for the system to work - Looks like we are getting somewhereAbout 12v black/yellow to green and black - Good
black/white to green and black ~0.01 - Not good
Last edit: 18 Jun 2026 02:56 by Wookie58.
- F64
- 81-KZ440D2
18 Jun 2026 02:56
yeah, i was looking at an older schematic.
The red/yellow wire is still the 12+ on your bike.
I'm trying to find a schematic for your bike.
The older 10 pin connector does have a diode bank connected to the igniter under the left side cover.
You may have that as well, but i'm going to do more searching for your schematic first.
81-KZ440-D2.
LIC, NY
LIC, NY
18 Jun 2026 02:58Mike the OP has posted it further up the thread it's the second pic (same system I have installed on my project from a GPZ1100) looking at the results on the black/white I suspect the diode bank is the issueyeah, i was looking at an older schematic.
The following user(s) said Thank You: F64
- SvansLös
18 Jun 2026 03:18OK so it looks like the "Diode Pack" is faulty - do you know how to test diodes in both directions ?Ok!no difference when pulling the clutch!
You could also make a bridging link with a 5amp fuse in it, re-connect the plug to the igniter and bridge the black/white to the black/yellow across the back of the plug - does it start now ?
- F64
- 81-KZ440D2
18 Jun 2026 03:18
Wookie,
Is the wire coming from the diode bank black/white or brown/white?
Black/white looks like one of the wires coming from an ignition pick up.
81-KZ440-D2.
LIC, NY
LIC, NY
18 Jun 2026 03:24Good call, on this schematic it's brown and white (GPX and GPZ are black/white) - it's the one from pin3 on the igniterWookie,
