Very frustrated now bike runs bad again
  • zed1015
  • zed1015's Avatar
  • Away
Re: Very frustrated now bike runs bad again
20 May 2024 10:30
#899381
It doesn't matter if the kill switch is left on.
It is only live when the ignition is on..
The following user(s) said Thank You: Wookie58, Rolf1976_KZ900
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar Topic Author
20 May 2024 10:41
#899382
Thanks that was good to hear. I just had another look at the alternative wiring diagram that i used and saw that when using a direct fused wire to battery positive from coils it did not connect with   the red/yellow wire coming from killswitch .
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
20 May 2024 11:31
#899385
The direct feed for the coils isn't an issue as no current flows until the BB module is activated by the ignition via the kill switch, however if the "kill switch" is faulty you still have a "point of failure" which will stop the bike running. Also if the kill switch is arcing then it will cause power surges which could damage your new module (I don't know how sensitive they are)
The following user(s) said Thank You: Rolf1976_KZ900
  • Rolf1976_KZ900
20 May 2024 13:38
#899393
Ok thanks next up is inspecting the killswitch just to be sure all is working right.
  • Rolf1976_KZ900
23 Jun 2024 14:05
#901196
I still have not open the killswitc,. but i now know for sure it is worn out or damaged .That is because yesterday when on a trip the bike suddenly did not react when pushing the start button.Then i touched the killswitch that was in ON position the bike fired right up.So maybe that is what made one coil melt last year and bike run bad.
The bike runs fine now but that killswitch is a weak point that make some electrical gremlins.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
24 Mar 2025 02:47
#910440
Morning Rolf, did you see my email ??
  • Rolf1976_KZ900
24 Mar 2025 11:10
#910460
Yes i found it now in my spam mail . i did not read careful enough what is in my spam mail but now i found it and replied. Thanks!
