Reproduction speedo OEM replacement
  • DoctoRot
  • DoctoRot's Avatar Topic Author
27 Dec 2019 13:24
#815945
No eBay APP ID and/or Cert ID defined in Kunena configurationAny one have any experience with these reproduction speedos? Seems like a good alternative to taking a gamble on a used one off eBay.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Reproduction speedo OEM replacement
27 Dec 2019 13:43
#815946
I had two of them. Both failed in 4000 miles.
kzrider.com/forum/5-chassis/599906-new-tach-speedo
  • hardrockminer
  • hardrockminer's Avatar
27 Dec 2019 20:56
#815987
My recommendation would be to buy one on ebay and send it to ZResto to be rebuilt.
  • DoctoRot
28 Dec 2019 00:39 - 28 Dec 2019 00:41
#815995
Both the tach and speedo needles wag really bad.. they are both nearly unreadable. I read is an issue caused by the magnet losing strength that cannot be repaired. I’m not confident of any of the 40 year old examples I see on eBay even a NOS one for this reason.
I read through that thread Steve, good info there. Did you ever get the new batch of gauges?
Last edit: 28 Dec 2019 00:41 by DoctoRot.
  • asphalt900
  • asphalt900's Avatar
28 Dec 2019 03:55
#815998
Doc before You give-up on your existing instruments would you have any interest in an attempt to "possibility" rectify their misbehavior? Mikaw sent me a set that need to be done and I promised him a pictorial of each step thru this forum. I can use his as an example but don't want to hijack your text.
  • DoctoRot
28 Dec 2019 10:33
#816006
How do you solve the wagging issue?
28 Dec 2019 10:56 - 28 Dec 2019 10:57
#816007
DoctoRot wrote: Both the tach and speedo needles wag really bad.. they are both nearly unreadable. I read is an issue caused by the magnet losing strength that cannot be repaired. I’m not confident of any of the 40 year old examples I see on eBay even a NOS one for this reason. ...
The original gauges on my 1977 KZ650 still work fine after 62,000+ miles. Is it possible that the cables are the problem? Is there any way to test the gauges without using the cables. Ed
Last edit: 28 Dec 2019 10:57 by 650ed.
  • hardrockminer
28 Dec 2019 13:20
#816019
I am told that there are oil filled dampers inside the gauges and that when the oil eventually weeps out the needles will not hold still.
  • DoctoRot
28 Dec 2019 13:27
#816021
Cables are new. I seem to recall the manual saying you should always store the gauges upright. Perhaps this has to do with the oil .
  • hardrockminer
28 Dec 2019 17:23
#816036
I believe it does. I know when ZResto ships them he sits them upright.
  • Mikaw
  • Mikaw's Avatar
28 Dec 2019 21:22
#816050
I know the tach has a fluid damper... See photo of mine... I assumed the shading was sun fade, but asphalt900 told me it was fluid that had leaked out of the damper
  • Rick H.
  • Rick H.'s Avatar
29 Dec 2019 07:49
#816055
I just had my gauges restored by ZResto and they look great, almost too nice to install. I may just mount them on a frame and put them over my fireplace mantel. I asked about the oil in the gauges and was told it wasn't a big deal if they weren't straight up and down for a short period of time. You really have no control over how the gauges are situated when they are shipped anyway. "This Side Up" to a worker bee means turn them over. Anyway, I am very happy with how my gauges look.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
