1981 kz750e
- Dan-kz
Re: 1981 kz750e
17 Jun 2015 20:11
I have tried to get them level with the clear tube, but 1 and 4 will not come up any higher - level. Wise
Although I have. A new fuel filter on to line before the cards I still have so much crap getting into to bowls.
I have to do another tare down and clean them better and also look at the footer valves on 1 and 4 that's the cost of being a newbe but I,ll get there
Thank you for the help I'm so glad to have found this Site. Dan
- Tyrell Corp
Re: 1981 kz750e
18 Jun 2015 05:13
I use a length of dog lead chain and rattle it around inside the tank, after taking the tap and fuel level sender off. The metal is thin and can get 'dingers' so don't use heavy chain. Some string attached helps when fishing the chain out.
Re: 1981 kz750e
18 Jun 2015 11:05
That'll work.
Don't bend the tangs too much. They will jam the needle to the side and cause leaking. Bend the float balls up slightly and have the tangs almost level. Use them to fine adjust the fuel level.
The following user(s) said Thank You: Dan-kz
- JR
Re: 1981 kz750e
18 Jun 2015 11:39
And make sure floats are not upside down
Re: 1981 kz750e
18 Jun 2015 13:20
That's right. Look for the witness marks from the needle on the tangs.
- Dan-kz
Re: 1981 kz750e
18 Jun 2015 19:41
I used k1 kerosene. Added an online fuel filter but when I open the prim and run gas. Into a white pan I see soft gelled spots in the pan. I'll flush it out again tell it comes back clear.
Re: 1981 kz750e
18 Jun 2015 21:24
Soft gelled spots? That might be water. I'd like to know for sure though.
- Dan-kz
Re: 1981 kz750e
19 Jun 2015 20:37
Yes I think you are right it is water from the vintage water mix to remove the rust
The tank looks so much better inside and at the end of the day gas is cheep so I'll. Change it out.
Thank you Dan
Thank you Dan
- Dan-kz
Re: 1981 kz750e
23 Jun 2015 07:51
Ok bikes all back together but will not start.
It turns over sputters then backfires through the carbs?
- Dan-kz
Re: 1981 kz750e
23 Jun 2015 18:03
Coil wire power leads reversed?
- Dan-kz
Re: 1981 kz750e
24 Jun 2015 08:19
No the wires are okay I'm thinking the cam chain tensioner?
