1981 kz750e
  • Dan-kz
  • Dan-kz's Avatar Topic Author
Re: 1981 kz750e
06 Oct 2015 08:54 - 06 Oct 2015 08:55
#693573
Yeah I seen some descriptions in the PDF I downloaded about whetstone on the teeth but did not see anything worth stoning on the gears I have it was just weird don't even know what it was just happy it works
Last edit: 06 Oct 2015 08:55 by Dan-kz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • KZB2 650
  • KZB2 650's Avatar
Re: 1981 kz750e
06 Oct 2015 11:25
#693590
This is good news....... please keep us updated on your first couple rides. :woohoo:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: Dan-kz
  • Dan-kz
Re: 1981 kz750e
07 Oct 2015 06:37 - 07 Oct 2015 06:39
#693650
Think you nailed it on the head even though I thought it was the primary chain jumping crank it must have been a starter issue starter clutch issue pardon me and you know my haste and fury I overlooked it things are fine now thank you.
Last edit: 07 Oct 2015 06:39 by Dan-kz. Reason: Typo
  • Dan-kz
Re: 1981 kz750e
07 May 2016 18:04
#725120
So I did get it all back together and had it running but the main fuse keeps blowing ? Don't know why it was so sweet to rip up the road but now the fuse keeps blowing errrr
The following user(s) said Thank You: Tirefire Pat
  • JR
  • JR's Avatar
Re: 1981 kz750e
07 May 2016 18:27 - 07 May 2016 18:29
#725126
Great that you got it running
The only reason to blow the main fuse would be a short circuit. Happened to me and i followed the wires and found the culprit in the headlight bucket.. the PO had used hockry tape on a connection and when the tape fell off a wire was making contact with bare metal.
Mfolks postef a more methidical approsch here.
www.kzrider.com/forum/4-electrical/454621-how-to-find-a-short
Good luck
Last edit: 07 May 2016 18:29 by JR.
  • Nessism
  • Nessism's Avatar
  • Away
Re: 1981 kz750e
07 May 2016 19:05
#725131
Might want to check the charging system too to be sure it's not over charging.
