1982 Kawasaki kz550 LTD no response in cluster
  • Motor Head
  • Motor Head's Avatar
Re: 1982 Kawasaki kz550 LTD no response in cluster
09 May 2013 00:28 - 09 May 2013 00:46
#586499
That is really great news! I was thinking that there was something either unplugged or a bad connection. Kinda hard steering the diagnosis over the web.
Shoot up a picture of the Offending Black Wire connectors. Is it Black plugged into a Black with a yellow stripe?
If so make sure your battery is connected properly. Both the cable and the Black/ Yellow striped wire hooked up to the negative terminal. The black/ yellow is for the whole Ground for the electrical, besides the Starter Motor. The Battery cable is for the starter.
Last edit: 09 May 2013 00:46 by Motor Head.
