1982 Kawasaki kz550 LTD no response in cluster
  • Bkirk24
  • Bkirk24's Avatar Topic Author
Re: 1982 Kawasaki kz550 LTD no response in cluster
09 May 2013 00:05
#586485
Okay so with the switch on, the fuses in, and the harness disconnected from the ignition switch, I'm reading from both sides of that connected I posted the picture of and am getting a steady 11.6V from the White wires
First bike!
  • Motor Head
  • Motor Head's Avatar
09 May 2013 00:05
#586486
Bkirk24 wrote: There is 2 white wires, they both jump between 7-10V, they don't stay at a constant voltage
Try testing for voltage just an inch or so away, on the white where it comes up from the harness, just back from where the two are on the same Spade in the left side of the connector.
  • Motor Head
09 May 2013 00:07
#586487
Bkirk24 wrote: Okay so with the switch on, the fuses in, and the harness disconnected from the ignition switch, I'm reading from both sides of that connected I posted the picture of and am getting a steady 11.6V from the White wires
Now your Talking!!! This is what you need and I was expecting to see way back the other day.
  • Motor Head
09 May 2013 00:08 - 09 May 2013 00:08
#586488
So OK. Time to plug your connector back in. Using the Diagram, you see the switch contacts. Turn the switch to On, and check the Brown wire for power.
Last edit: 09 May 2013 00:08 by Motor Head.
  • Bkirk24
09 May 2013 00:09
#586490
So I want to be checking the brown wire coming from the switch correct?
First bike!
  • Bkirk24
09 May 2013 00:12
#586491
The brown wire coming from the ignition switch, disconnected and not running back into the bike is a jumpy voltage of 0.3-0.5V
First bike!
  • Motor Head
09 May 2013 00:12
#586492
Yes, from the switch, the connector plugged in, main fuse in place.
Then the Yellow Wire, Both the Brown and the Yellow need to have Power when the Key is turned to On.
  • Motor Head
09 May 2013 00:13
#586493
Bkirk24 wrote: The brown wire coming from the ignition switch, disconnected and not running back into the bike is a jumpy voltage of 0.3-0.5V
Switch is On? Is this the New Switch or old switch?
  • Bkirk24
09 May 2013 00:14
#586494
This is the new switch, I can plug in the old one and see what it gives me really quick
First bike!
  • Bkirk24
09 May 2013 00:16
#586496
With the old one plugged in I get voltage to the White and yellow with the switch turned on, no power to the yellow when the switch is off, and 11.6V to the brown wire, which is far more than I'm getting in the brown wire of the new switch...
First bike!
  • Motor Head
09 May 2013 00:21 - 09 May 2013 00:24
#586497
OK, so your Old original switch is ok, not impressed with the New one.
So you have power out on Both of your circuits. Now to move down the line. The Yellow also has a connection, like the brown, where it Plugs in. These are "Bullet" connectors, single wire terminal. Make sure the yellow wire is plugged in, i believe it will also be there in the head light bucket.
The Yellow runs over to the Handle Bar switch for the right side, start button and On/ Run switch. This will turn the ignition On and operate solenoid when you push the Starter button.
Last edit: 09 May 2013 00:24 by Motor Head.
  • Bkirk24
09 May 2013 00:24
#586498
Found a black wire in the harness in the headlight, plugged it in and all the electrical systems worked! holy shit! so excited!
First bike!
