Megasquirt / Microsquirt a KZ
- 750steve
Re: Megasquirt / Microsquirt a KZ
13 Apr 2013 17:45
No chance am i letting myself near building 1 of those, WAY too much i can mess up! lol
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- steell
13 Apr 2013 17:56750steve wrote: No chance am i letting myself near building 1 of those, WAY too much i can mess up! lol
$645 fully assembled as listed above, $468 in DIY kit form.
I'm proficient with a soldering iron, so I build the kits. MS1 and MS2 so far.
- 750steve
13 Apr 2013 18:14
Where from? I think I'll be ok with micro at the minute. If I ever go to the mega I'd be safer paying the extra for it to be built, you've 'known' me a while Steve, I'd be more proficient at making myself sterile with a soldering iron!!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- steell
14 Apr 2013 15:51750steve wrote: Where from? I think I'll be ok with micro at the minute. If I ever go to the mega I'd be safer paying the extra for it to be built, you've 'known' me a while Steve, I'd be more proficient at making myself sterile with a soldering iron!!
Now that's a disturbing mental picture!! :laugh:
I buy from diyautotune here in the US, I don't remember the name of the UK distributor, but I remember he was/is a big contributor to MegaSquirt.
- 750steve
14 Apr 2013 16:08
Phil Ringwood
www.extraefi.co.uk/
I've dropped him mail about a gauge he can suggest for A/F & Boost, i'll post up if he suggests anything
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
16 Jun 2013 22:33
Guys, sorry to resurrect this, its 2.30am here & i cant read through the thread again.
What did you guys use for cyl head temp measurement? Or what sensor? My GPz Turbo head has a M10x1 hole for the original sensor (which cant be used) & the recommended GM sensor is WAY too big for the hole (16.5 ish mm wide)
I've found this, but i don't know how reliable it'll be!
thesensorconnection.com/cht-sensors/cht-...erature-12-and-14-mm
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- floivanus
16 Jun 2013 23:16
Might try the coolant sensor from like an 01 dodge ram, they use a smaller thread on them dunno the size tho
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Motor Head
17 Jun 2013 00:06 - 17 Jun 2013 00:13750steve wrote: Guys, sorry to resurrect this, its 2.30am here & i cant read through the thread again.
I believe these are the thread you are looking for. But I do not know if they are what you need for the resistance values. They are pretty common through the Bosch Fuel injection Air Cooled VW and Porsche. www.texasaircooled.com/catalog/Type-4-Cy...perature-Sensor.html
Here is a link to the resistance at different temps. www.ratwell.com/technical/TempSensorII.html
Last edit: 17 Jun 2013 00:13 by Motor Head.
- steell
17 Jun 2013 01:28 - 17 Jun 2013 01:34
Why can't you use the stock sensor? I believe you can change the values MS expects in Mega Tune and Tuner Studio tuning software. I believe it's discussed in the Mega Manual.
Had to refresh my memory :
Mega Manual
I think the MicroSquirt is basically a MS II.
These sensors were been used on practically all GM cars in the 1980s and are easy to find - the same is true for the correct connectors. However, other sensors can be used if the EasyTherm software is used to recalibrate your MegaSquirt® EFI controller.
Easy Therm
If you are using non-standard coolant and/or air temp sensors with a MS-I™ controller, you must create “.inc” files that are essentially look-up tables for your MegaSquirt® EFI controller to relate resistance to temperature (For MS-II™ you can change the curves directly in TunerStudio, with no other steps necessary). These files must then be compiled into one .s19 file, and then down loaded to the MegaSquirt® controller. EasyTherm makes it very easy to use “non-standard” temperature sensors with the MegaSquirt® controller. It does three things that otherwise can be a bit of a pain:
Mega Manual
Note that you do not need EasyTherm with MS-II, you can calibrate the thermistor tables directly in TunerStudioMS (under 'Tools') without reloading code.
Last edit: 17 Jun 2013 01:34 by steell.
- 750steve
17 Jun 2013 22:29 - 17 Jun 2013 22:30
Thanks Guys.
Motorhead, thanks for looking that link up, what i need is a 2 wire sensor, apparently more accurate, i've kinda found one but i'll use the stock sensor as Steve says, might as well give it a go & i have the resistance values.
Steve, yes the uS is more or less an MS2, a few less functions. I'll get this one running & then use it on my next bike, i'll maybe MS3 the turbo bike at that time. It says in the Manual or uS/MS2 doccumentation to use the 2 wire sensor but through discussion the original one might be ok as bike wire runs are so short (well thats what i was told). A guy on the turbo forum has just got his bike started on MS2 using the original sensor so that gives me some hope.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 17 Jun 2013 22:30 by 750steve.
- Motor Head
17 Jun 2013 22:58
Wouldn't a sensor with a thermo pellet, be for immersing in liquid? The water temp sensors are two wire and a thermo pellet, when there is no liquid they go nuts.
Got a sensor in mind, can you post a link?
- steell
17 Jun 2013 23:52
The MegaSquirt and most other EFI computers uses two wire sensors to reduce the electrical noise due to grounding. Ground wire goes to computer ground.
