1980 750H bare bones for mattylight
  • loudhvx
  • loudhvx's Avatar Topic Author
Re: 1980 750H bare bones for mattylight
11 May 2008 10:22 - 09 Jan 2019 14:58
#212799
mpatrick19 wrote:
i have a stock electronic ignition, could i just use the diagram for the dyna s for reference? Its an 82 kz750 n1.
There are a few differences such as which coil is mounted on which side and the reg/rec is a single unit. some of the wire colors are different.
1982 KZ750 KZ750N1 bare bones for Mpatrick19
EDIT 1/9/2019:
Mattylight Barebones Bare Bones Wiring Diagram
1982 Kawasaki Kz750N1 for Mpatrick19
Kz750N Kz750 N1 Kz 750 N 750N1 750N
Last edit: 09 Jan 2019 14:58 by loudhvx.
  • mpatrick19
  • mpatrick19's Avatar
  • 1982 kz750 spectre
11 May 2008 20:08
#212955
thanks this is awesome.
1982 kz750 spectre
  • mattylight
  • mattylight's Avatar
18 May 2008 12:02
#214355
Wow, its been awhile since I've been on this thread and I'm amazed by how many responses there are now... loudhvx is the man!! I've been doing a lot on the bike recently and I finally finished enough to fire it up and first button push it worked great! Thanks for all your help!
Matt
  • loudhvx
19 May 2008 00:44 - 09 Jan 2019 15:37
#214488
Glad it worked! :)
EDIT 1/9/2019:
I don't know where else to put these, so I'll put them here. They were probably in other threads originally, but chronologically, they would go about here if they were in this thread.
1974 Kawasaki Z1 with Kz1000 reg/rec and Dyna S for BigBlockT
Kz900 Kz 900 Kz 1000
1978 Kawasaki Kz650 with GSXR controls for Caffcruiser
Kz 650
1982 Kawasaki Kz1100D1 Spectre for Wagonmaster
Kz1100D Kz1100 D1 Kz 1100 D 1100D1 1100D
Last edit: 09 Jan 2019 15:37 by loudhvx.
  • snerff
  • snerff's Avatar
26 May 2008 01:19
#215881
Another question for loudhvox. I am planning to hook up an external alternator. Can I run that along with the bike motor alternator? It is a one wire alternator. Almost finished with your great bare bones wiring diagram. Hope to start it soon. I think I need the extra charging as I am running an electrical reverse gear drive.
The engine is going in the large buggy and not the motorcycle so reverse is important. Thanks again for all your past help. I hope to have pictures soon to share with everyone.
  • loudhvx
26 May 2008 08:01
#215917
The one wire alternator will have a built-in regulator/rectifier. Since the bike, now cart, has its own regulator, there will be two regulators fighting over control of the voltage. If the bike is using a lot of electricity it's not a problem, but when the bike has too much electricity, the bike regulator may fry.
You could maybe put in a switch so the KZ alternator/rectifier/regulator only comes on when the reverse is used. The single-wire (GM?) alternator should have more than enough power to power the cart during normal times.
You could also use a really big, (Or a bunch of small) diodes to reduce the voltage coming out of the GM alternator. This would make it provide current only under heavy load, such as when the reverse is used.
I'm sure there are other configurations that might work as well.
The main thing, though, is that you will need a much bigger battery, like a car battery. (I don't remember if you already said you are going to do that.) The alternators might only provide 20 amps or so at idle (which is probably what the engine will do when you're backing up). You need a big battery to give you the extra current.
I think the simplest solution, however, would be to just use a car battery and don't bother with the external alternator.
Better yet, but more work, would be to delete the KZ alternator/reg/rec and use only the external alternator. It would give you more electrical power (and is better suited to such extremely varying loads), but will require more fabrication. Some people put a pulley where the original alternator was and run a belt to the external alternator.
  • snerff
  • snerff's Avatar
27 May 2008 01:10
#216092
Again, as usual, you were a big help. Thank You.
  • cherrymetal
  • cherrymetal's Avatar
15 Aug 2008 04:57
#232124
Question for Loudhvx,
I'm after a diagram for my z650 fitted with gpz750 engine (and ignition system etc). I don't want any of the cut outs (clutch, side stand etc) and I don't want the indicators, but I'll need everything else (gauge lights, headlight & taillight) Being in the UK I won't need the headlight on all the time. Can you help at all?
I've printed off the ignition/charging system from the beginning of this thread, which was a great help, but I'll need all the rest - cos I ain't that clever!
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
  • loudhvx
21 Aug 2008 09:39 - 09 Jan 2019 15:07
#233278
Sorry, I don't really have time to go through all of the gauges etc. If you're keeping all of that, then a stock wiring diagram will be more useful anyway.
I don't know what year your gpz motor is, but here is a generic diagram to show ignition and charging to get it running, and a generic setup for some lights and basic idiot lights. All the rest of the gauge lights etc can be wired into the area to the right.
1977 KZ650 with GPZ750 motor, bare bones for Cherrymetal
EDIT 1/9/2019:
1977 Kawasaki Kz650 with Kz750 engine for Cherrymetal
Kz 650 Kz 750
Last edit: 09 Jan 2019 15:07 by loudhvx.
  • loudhvx
31 Aug 2008 11:31 - 09 Jan 2019 15:11
#234802
This is for Dulcimerbob.
You can probably go off this diagram I made for Cherrymetal's GPZ750. Your 84 GPZ550 should be very similar. Also, yes, you can just use individual spade connectors on the reg/rec. I often do. I like it because it's less bulky and I can hide the wiring better that way. But definitely get a good ratcheting crimper, otherwise you will waste your time.
Here's a decent one:
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93977
EDIT 1/9/2019:
1984 Kawasaki Zx550A1 gpz with Kz550 ignition for Dulcimerbob
Zx550A Zx550 A1 Zx 550 A 550A1 550 A Kz
Last edit: 09 Jan 2019 15:11 by loudhvx.
  • loudhvx
Re: KZ400 for oldkaws4ever
29 Oct 2008 10:33 - 09 Jan 2019 19:46
#244480
This is for an S model but should be the same.
1976 KZ400 S2 KZ400S2, bare bones.
for oldkaws4ever
EDIT 1/9/2019:
1976 Kawasaki Kz400S2 for oldkaws4ever
Kz400S Kz400 S2 Kz 400 S 400S2 400S
Can't seem to find this one for some reason.
I suggest using the one for Zeffrides. It is on page 19 of the Mattylight thread.
post number 703075. 14 Dec. 2015.
If I find the original drawing I'll post it here.
(No new image yet)
Last edit: 09 Jan 2019 19:46 by loudhvx.
  • snerff
  • snerff's Avatar
16 Feb 2009 00:55
#265301
Hi to all. I finally got around to wiring the engine using the diagram from Loudhvox. It started the first time, again, thanks Loudhvox.
