1980 750H bare bones for mattylight
  • loudhvx
  • loudhvx's Avatar Topic Author
Re: 1980 750H bare bones for mattylight
14 Sep 2013 14:29 - 14 Jan 2019 18:28
#606409
Thanks D.
1982 KZ1000K2 Ltd. for Beaner242 based on 1981 KZ1000K1 Ltd.
EDIT 1/14/2019:
Mattylight Barebones Bare Bones
1982 Kawasaki Kz1000K2 for Beaner242
Kz1000K Kz1000 K2 Kz 1000 K 1000K2 1000K
Last edit: 14 Jan 2019 18:28 by loudhvx.
  • Beaner242
  • Beaner242's Avatar
16 Sep 2013 22:43
#606731
Thanks so much
1982 KZ1000K LTD Chopper
  • loudhvx
24 Oct 2013 12:18 - 14 Jan 2019 18:30
#611033
Kawasaki KZ900 points, with and without battery.
For fastestz1.
Batteryless version requires reg/rec sense line tied directly to reg/rec output, and also requires lights to be off when starting, so requires on/off switch for lights.
EDIT 1/14/2019:
Kawasaki Kz900 with and without battery for FastestZ1
Kz 900
Last edit: 14 Jan 2019 18:30 by loudhvx.
  • Beaner242
24 Oct 2013 12:24
#611034
what program do you use to draw these?
  • loudhvx
24 Oct 2013 12:33
#611035
Just plain old Microsoft MSpaint. It comes on every version of Windows so it's convenient for me. I can't install programs at work, but it's already there. I'm sure any raster drawing program should be able to edit it.
The following user(s) said Thank You: Beaner242
  • loudhvx
27 Nov 2013 13:04 - 14 Jan 2019 18:32
#614234
1981 Kawasaki KZ650D4 for Ehde.
with automotive ignition switch.
EDIT 1/14/2019:
1981 Kawasaki Kz650D4 with aftermarket ignition switch for Ehde
Kz650D Kz650 D4 Kz 650 D 650D4 650D
Last edit: 14 Jan 2019 18:32 by loudhvx.
  • ehde
  • ehde's Avatar
30 Nov 2013 05:59
#614440
Awesome! I'm so grateful!
One question though. My ignition switch only have three positions. Off-ign-start, I suppose this will make a differene?
Thanks!
  • loudhvx
04 Dec 2013 11:01
#614767
been really busy. I'll redo it when I get some time.
  • loudhvx
06 Dec 2013 03:25 - 14 Jan 2019 18:34
#614894
1981 Kawasaki KZ650D4 SR for Ehde.
Redone using relay instead of common car ignition switch toturnoff lights while starting.
EDIT 1/14/2019:
1981 Kawasaki Kz650D4 with automatic headlight dimmer for Ehde
Last edit: 14 Jan 2019 18:34 by loudhvx.
  • loudhvx
21 Jan 2014 23:39 - 14 Jan 2019 18:35
#619583
1981 Kawasaki KZ550C2 Ltd. for Calebjkd
EDIT 1/14/2019:
1981 Kawasaki Kz550C2 for Calebjkd
Kz550C Kz550 C2 Kz 550 C 550C2 550C
Last edit: 14 Jan 2019 18:35 by loudhvx.
The following user(s) said Thank You: Calebjkd
  • Calebjkd
  • Calebjkd's Avatar
22 Jan 2014 00:08
#619585
Im a little confused, may just be inexperience.
Between the Starter button and the starter solenoid where the wire goes from blk (@ button) to red/yel (@ solenoid), is this a ground wire?
Or is it to complete the circuit?
'81 Kawasaki kz550 ltd
'71 Yamaha xs650
  • Calebjkd
  • Calebjkd's Avatar
22 Jan 2014 00:49
#619586
Nevermind, figured it out!
Thanks for the time and effort loudvhx.
My bike thanks you too!!
'71 Yamaha xs650
