Idle is out of control
- jwinatlanta
04 Aug 2026 18:58
Just finished rebuilding my rack of cv 32 carbs. Put them back on the engine. after a few burps and bangs it fired off.
It fired and immediately revved to 6k.I screwed the idle adjust screw almost all the way out. I fired it up and once again
it revved to 6k.Loosened the throttle cable from its mount. Still 6k.
What should I do next???
- StreetfighterKz
Re: Idle is out of control
04 Aug 2026 19:02
Did you bench sync the carbs at all? Could be out of adjustment and one butterfly is almost closed and holding the rest open too far?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- jwinatlanta
04 Aug 2026 19:16
Bench synced the full rack. All seemed correct at the time of installation.
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
04 Aug 2026 20:00
Make sure that the throttle snaps shut and isnt hitting anything. Most of the time a carb holder clamp is positioned where the bolt stops the throttle assembly from fully closing.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
05 Aug 2026 01:49
Are the vacum ports capped ?
The following user(s) said Thank You: asphalt900, Warren3200gt
05 Aug 2026 04:03
Vacuum leak. If the rubber carb boots are original, they could be deteriorated and cracked.
The following user(s) said Thank You: potatozard
- jwinatlanta
05 Aug 2026 14:18
Ness,
I know you are a carb man. I didn't realize a vacuum leak would make the idle run high. I just thought a vacuum leak would cause it to run rough.
Yes the boots are the original. Guess thats my next step
Bound,
Checked the clamps. They were not in the way but that was a good call.
Wookie,
All ports are capped off.
Bound,
Wookie,
The following user(s) said Thank You: Wookie58, bound
05 Aug 2026 21:45
If the vacuum caps are as old as the carb holders, you will want to replace them, too. A quick inspection of the vacuum hoses is also in order.
- jwinatlanta
06 Aug 2026 15:45
Tex
I should have stated that all vacuum ports are capped with new caps. Taking Nessisms advice I just ordered new carb holders from Z1.
07 Aug 2026 02:30
When the carbs are off hold them up to the light and ensure all throttle flaps are closing fully
The following user(s) said Thank You: Warren3200gt
- jwinatlanta
07 Aug 2026 14:56
Wookie they are cracked open slightly. Thanks for the suggestion.
So I took the carb holder/intake boots off this afternoon and made an observation. Out of the eight screws only two were
relatively tight. The others were a bit more than finger tight. All the gaskets were in several pieces. Inspecting the boots,
there are no obvious holes or cracks.Since I have more time than money, this weekend I am going to make some new gaskets.
Tightly screw on the boots. Mount the carbs. AND.................You just never know!
The following user(s) said Thank You: StreetfighterKz, Wookie58
08 Aug 2026 05:09
The original rubber carb boots don't use gaskets. There is a raised lip on the rubber boot that acts as the seal. If there are gaskets, that means that someone applied a band-aid fix, that didn't last. And speaking of the boots, the aftermarket options range from decent to junk. Kawasaki still sells the OEM parts, which are more money, but worth it for peace of mind (my opinion)
