Idle is out of control
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Idle is out of control
29 Aug 2026 09:41
#927090
With the idle screw all the way out they should be completely closed- then wind the idle screw in to open the carb it acts on and complete a static sync on the other three - wind the idle screw back out and check they are closed- now when you adjust the idle screw it will open them all slightly which will allow it idle
The following user(s) said Thank You: rickysnicker
  • jwinatlanta
  • jwinatlanta's Avatar Topic Author
29 Aug 2026 10:59
#927094
Snicker do what Wookie says. The peeps in this thread got me from idling at 6K!!!!!!!!!!
The following user(s) said Thank You: Wookie58, rickysnicker
  • rickysnicker
  • rickysnicker's Avatar
01 Sep 2026 12:21
#927183
Thanks.  Im in Missouri for a month.  When I get back home, I will do as you all have suggested.   Also, apologies if I derailed this thread.
  • Nessism
  • Nessism's Avatar
01 Sep 2026 15:59
#927189
As mentioned by Wookie earlier: hold the carbs up to the light with the idle screw backed off, and make sure there is no light showing around the butterflies.  Adjust as needed, including the bench sync.
