AFR RESULT
- zed1015
Re: AFR RESULT
15 Jun 2026 05:42The air correctors are the right size for the CARBS regardless of what bike they are on.I think about it.. does my Air corrector could be not right for my bike?
- Maxbou92
Re: AFR RESULT
15 Jun 2026 05:46
Thank you Zed!! I just try to figure out my richness problem..
Kz750e 1980
Re: AFR RESULT
15 Jun 2026 05:48What condition are your choke plungers in ?Thank you Zed!! I just try to figure out my richness problem..
- Maxbou92
Re: AFR RESULT
15 Jun 2026 05:56Are they closing fully ? on my BS34's the linkages where bent (probably from being pulled too hard) so they weren't seating fully until I straightened the bracket (when the choke is off can you push the plungers down at all ?Brand new!! Niche one
- Maxbou92
Re: AFR RESULT
15 Jun 2026 06:02
Yes they are!!! I try to push them down yesterday.. everything is ok with plungers!! Float level 3-4mm with clear tube (26mm with my rule) !! I have never experimented problems like that with my ATV !!! I love my old KZ that why I keep going with it !!
Kz750e 1980
Re: AFR RESULT
15 Jun 2026 06:11Doesn't make a lot of sense, are your #15 pilots genuine Mikuni or have they been reamed out by somebody trying to clean them ?Yes they are!!! I try to push them down yesterday.. everything is ok with plungers!! Float level 3-4mm with clear tube (26mm with my rule) !! I have never experimented problems like that with my ATV !!! I love my old KZ that why I keep going with it !!
- Maxbou92
Re: AFR RESULT
15 Jun 2026 06:15 - 15 Jun 2026 06:16
I know!!! I disassembled all of them before dyno last year to clean them in Ultrasonic Machine.. all jets are Mikuni one!! Could it be my Porting?! Valves are on specs (rebuilt engine) my idle is now set at 13.5 - 14 afr. 1/8 throttle bang 10afr
Kz750e 1980
Last edit: 15 Jun 2026 06:16 by Maxbou92.
Re: AFR RESULT
15 Jun 2026 06:24I wouldn't think so - worth investigating injected's ignition theory - do you know anyone with a crypton style tuner that can measure the Kv in your plug leads when running ?I know!!! I disassembled all of them before dyno last year to clean them in Ultrasonic Machine.. all jets are Mikuni one!! Could it be my Porting?! Valves are on specs (rebuilt engine) my idle is now set at 13.5 - 14 afr. 1/8 throttle bang 10afr
- Maxbou92
Re: AFR RESULT
15 Jun 2026 07:40
Humm no I dont!! Today I will try it with my Needle on clip one and then 0.3mm washer!! I just finished to synchronize my carbs with my gauge.. I have another CDI on my box, OEM one from eBay.. thats my last option!!
Kz750e 1980
- Injected
Re: AFR RESULT
15 Jun 2026 12:34 - 15 Jun 2026 12:36A weak spark at idle will not impede engine function at higher RPM.Thank you, so weak spark can happen at low rpm and can be perfect at WOT ?!
At higher engine speeds, the ignition system fires much faster, this builds builds more primary current in the ignition coil. Higher cylinder pressures, and turbulence at increased RPMs help the fuel-air mixture ignite more easily, temporarily masking a weak spark.
1978 KZ650B2 modified project
Last edit: 15 Jun 2026 12:36 by Injected. Reason: sp
The following user(s) said Thank You: Maxbou92
Re: AFR RESULT
15 Jun 2026 13:22A weak spark at idle will not impede engine function at higher RPM.Thank you, so weak spark can happen at low rpm and can be perfect at WOT ?!
At higher engine speeds, the ignition system fires much faster, this builds builds more primary current in the ignition coil (how does that work given that the "re-charge" time is shorter at higher revs ?). Higher cylinder pressures, and turbulence at increased RPMs help the fuel-air mixture ignite more easily, temporarily masking a weak spark. (I was always under the impression that the higher the pressure the harder the spark has to work, hence why plugs that spark outside the cylinder don't always spark when in the cylinder under pressure ?)
