AFR RESULT
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: AFR RESULT
13 Jun 2026 16:22 - 13 Jun 2026 16:24
#924846
Do Carb synchro could be not right?! I tune them with 1/8 drill bit. They look identical!!
that’s a great starting point but you need to vacuum sync to compensate for any efficiency difference between cylinders
PS: are you taking your AFR readings at a constant throttle or wacking it open and taking a reading
Last edit: 13 Jun 2026 16:24 by Wookie58.
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Re: AFR RESULT
13 Jun 2026 17:24
#924848
What do you think about first clip from top with 0.5mm washers?
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: AFR RESULT
14 Jun 2026 01:36
#924855
All you can do is experiment, it is that 1/8 - 1/2 where you are rich (and very lean on idle) ideally on an air cooled motor you want to between 12 & 13 across the board (or as close is achievable)
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: AFR RESULT
14 Jun 2026 01:36
#924856
The following user(s) said Thank You: Maxbou92
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: AFR RESULT
14 Jun 2026 05:09
#924859
If you are seeing differences between cylinders even though they are jetted identically, I would suspect something is wrong with the individual carbs. Either a clogged passageway or float levels.
Conversely, it could be a weak spark for those two cylinders. You could try swapping the coils.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Maxbou92
Re: AFR RESULT
14 Jun 2026 05:35
#924860
Thank youu. I installed 0hms plug cap, new wires (Ton’s wires 0 ohm). My Oem coils has both Oem  resistance. Thats so weird thar my afr is so rich at very light cruise at 60-70 mph. But after that is pretty good. Maybe drop needles from clip 1 or 1.5 (washers) ?!! Maybe its because the carbs are made for Kz900-1000 ?! 😬
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: AFR RESULT
14 Jun 2026 06:37
#924861
Are your pilot jets sized for a 750 or a 1000 ?
  • Injected
  • Injected's Avatar
Re: AFR RESULT
14 Jun 2026 07:10 - 14 Jun 2026 07:14
#924862
Are you using a OEM electronic ignition that has a ignitor box? Those have been shown to be bad but still work, a symptom is weak spark at low RPM. If using Dyna S disregard.
A 650/750 engine is OK with a #15 pilot jet, maximum would be #17.5 for some combinations but never higher than that unless its a race engine.
FYI - I have never heard of anyone using a Mikuni pilot jet of less than #15 and clipping a needle at #1 or #2 position.
A lot of so called carb issues are actually ignition related. Just because you see a spark does not mean its strong enough to be useable.
1978 KZ650B2 modified project
Last edit: 14 Jun 2026 07:14 by Injected. Reason: sp
  • Maxbou92
Re: AFR RESULT
14 Jun 2026 07:33
#924863
Thats weird, because with my old CV34 the bike was running fine at low rpm but worse than now at high rpm with Pods!! The VM could be too big for my 750? Yes Im using oem ignition box and coil!!  What ignition box should I use ?!
Kz750e 1980
  • Injected
  • Injected's Avatar
Re: AFR RESULT
14 Jun 2026 10:16 - 14 Jun 2026 17:21
#924865
No the VM carbs are not too big for a stock 750 engine, either 26 or 28's work with no issues. I have run RS34 flat slide on a 750 with no issues.
I thought I would mention the ignition only because you pilot and main sizes are fine for your setup. The only thing not normal is the lean needle clip setting. If your set lean on the needle and your running rich thru 1/8-1/4 then its not the jetting, its something else causing the richness.
I am just saying that in the past I have had a couple of Kawi Ignitor boxes that put out weak spark. I was getting spark but it was weak enough to cause combustion issues. If you have weak spark you will have a rich mixture, even if you have adequate compression. As soon as I switched to a Dyna S ignition plate (no box) it fixed the problem.
You can get China copy Dyna S pretty cheaply on Ebay, they work. I have one on my 1200 engine.
Last edit: 14 Jun 2026 17:21 by Injected. Reason: more info
  • Maxbou92
Re: AFR RESULT
15 Jun 2026 05:15
#924897
Thank you, so weak spark can happen at low rpm and can be perfect at WOT ?!
Kz750e 1980
  • Maxbou92
Re: AFR RESULT
15 Jun 2026 05:32
#924901
I think about it.. does my Air corrector could be not right for my bike?
Kz750e 1980
