Mikuni Flatslides Bell crank wheel
  • Injected
  • Injected's Avatar
Re: Mikuni Flatslides Bell crank wheel
23 Apr 2023 11:16
#883628
These exploded views might help, I put arrows to the pins/screws to remove.
1978 KZ650B2 modified project
The following user(s) said Thank You: rivman15
  • rivman15
  • rivman15's Avatar Topic Author
23 Apr 2023 11:17
#883630
Guys, I have to be doing something wrong here. That black throttle shaft is not letting these carbs separate. They are loose on bottom and top but are hung up on top. What am I missing?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Apr 2023 11:25
#883631
Don´t miss the choke shaft and plunger fork lifter screws.
  • rivman15
23 Apr 2023 17:21
#883656
Sciorcco, Whats your deal? Those pictures are before I even touched the carbs other than draining the bowls, I took your advice and it worked, I even said thank you.
  • rivman15
27 Apr 2023 04:58 - 27 Apr 2023 05:06
#883821
All back together... Thanks for the help. Still have one issue. The choke rod does not stay in a locked position when pulled out like my 36's. I took pictures and put back in exact position. I must have missed a step. Any help?
Last edit: 27 Apr 2023 05:06 by rivman15.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
27 Apr 2023 05:48
#883823
Go and get a big magnet and magnifying glass, you have to search for a needle in a haystack.
You lost the tiny little locking spring and steel ball parts# 51 and 52!!!
  • rivman15
27 Apr 2023 06:17 - 27 Apr 2023 06:17
#883824
 Thank you! Im back at work... I will have to look tonight when I get back home. I have both magnet and magnifying glass. This should be fun!
Last edit: 27 Apr 2023 06:17 by rivman15.
  • rivman15
27 Apr 2023 06:36
#883826
If by chance I do not find the two parts. Where can I source them? Did a quick google search and didn't see anything specific. Thanks.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
27 Apr 2023 07:00
#883828
Search eBay item number: 152374865348 and 162338222137
  • rivman15
27 Apr 2023 07:26
#883830
Man, I cant thank you enough. I just ordered them here at work because it was like $9.00 shipped. Guaranteed I find them tonight when I get home though because I bought them. Lol. I started working on them in the garage and then took them inside to finish. So they could be anywhere. Thanks again, Joe
  • rivman15
27 Apr 2023 07:48 - 27 Apr 2023 07:53
#883832
And where do they get installed on this? Inside carb #1 or 2?  Thanks.
Last edit: 27 Apr 2023 07:53 by rivman15.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
27 Apr 2023 09:58
#883846
Looks like you need two springs and steel balls installed in carb# 1 and #3.
See video at 29:00
