Need help getting carbs for 1985 Kawasaki ZN700
  • borop18
  • borop18's Avatar Topic Author
Re: Need help getting carbs for 1985 Kawasaki ZN700
22 Aug 2022 13:11
#872650
@rstnick, do you mind sharing a link to Pablo's tutorial?
I couldn't find stock carbs for the ZN700, so I got a set of Keihin CVK from a 1985 ZL750 Kawasaki Eliminator, getting them ready to install on my ZN700.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
22 Aug 2022 14:23
#872652
  • Nessism
  • Nessism's Avatar
22 Aug 2022 15:50
#872657
Did you join the 650 site I linked earlier?  The linked thread has tons of useful info about putting CKV carbs on your bike.
  • rstnick
  • rstnick's Avatar
22 Aug 2022 16:27
#872658
Yes, the information is on the 650 site which you will need to join to see.
Login (kz650.info)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s (aka GPz750)
1978 KZ1000 project
  • borop18
23 Aug 2022 13:24
#872712
Waiting on account aproval.
  • borop18
25 Aug 2022 10:04
#872827
So, I finally got the carbs ready to install and now the bike won't crank.
Checked all the fuses, they are good, there is power when I turn the key, but nothing happens when I press the run switch (checked the switch with a multimeter as well and it's good). Also checked the starter relay and that's good as well, when I apply 12V from the battery to the two contacts on the relay, the bike cranks.
I am suspecting the IC igniter, can that cause this issue?
Any ideas what to check next?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
25 Aug 2022 11:02
#872831
No, not the IC igniter but the side stand or clutch leveler safety switch if the engine is not in neutral.
  • borop18
25 Aug 2022 11:10
#872835
It is in neutral and it's on the center stand with the side stand up.
  • TexasKZ
  • TexasKZ's Avatar
27 Aug 2022 06:30
#872933
The switches can malfunction. It would be worth a minute or two to check them. Also check the Run Off Run switch for proper function. If they check out, then a careful, systematic check of the entire starter circuit is in order.
There is an excellent tutorial in the articles section of KZR.
The following user(s) said Thank You: borop18
  • TexasKZ
  • TexasKZ's Avatar
27 Aug 2022 06:38
#872935
Well, I was about 93.8% sure that Wookie58 had posted a diagnostic tutorial in the Articles section, but I’ll be hanged if I can find it. I guess I need a tutorial on finding tutorials
  • JR
  • JR's Avatar
27 Aug 2022 09:56 - 27 Aug 2022 09:57
#872940
Was looking for that yesterday also. Dont think it made it to the Filebase but if you go Search Tab, Keywords Fault Finding, User name Wookie58 that should get you to his post with the pdf
Last edit: 27 Aug 2022 09:57 by JR.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
27 Aug 2022 18:06
#872968
The following user(s) said Thank You: TexasKZ, Wookie58, borop18
