- Thank you received: 56
Difference in performance/use RS Flat Slide vs CR Round Slide - wrist fatigue
- 577nitro
The S1 came with the bath tub design cylinder head. It was the first Kz that used the bath tub cylinder head. Kawasaki then used the design head on the '83/'84 ZX1100's (GPz1100).
What throttle tube did you get with the Yoshimura throttle???
Mine came with the one on the left.
Nada...did not come with throttle. However, I did find this slick throttle tube from motoworks that uses bearings and does not ride on the bar at all and comes with all different size cable cams.
The search goes on...I did find some OEM throttle cables for my 81 GPZ550, thats about to be assemble after far too long. Still looking for OEM speedo, and clutch for that.
Plenty of Z900, Z1000 cables from japan. I might try those if the Z1R are un-attaineum.
577nitro
- daveo
- Thank you received: 654
If this was my situation, I would grab a couple 294673105517 and 140594394356...then cut to lengths and swap cables and fittings as needed.
Ran into that difficulty in 2016 while searching for cables for a ZN1100 dual-cable control housing which I chose to use with my RS carbs.
Nothing was (and nothing yet is) available for that setup...only option was to custom build them.
I'm still dumbfounded by how well they work.
What cables did you use? Is there some sort stock that can be used to fabricate the cables??
577nitro-
Only thing left is fabricate and secure knarps on the cut cable ends to fit the throttle grip.
1982 KZ1100-A2
- slayer61
- KZR FLAG RELAY CARRIER #62
Is this the one you're talking about?
577nitro
www.motosport.com/works-connection-elite-throttle-tube
That looks like a perfect candidate for my Mrs' bike.
- DoctoRot
- Thank you received: 675
I am going to try this variable rate throttle on my next build
www.revzilla.com/motorcycle/motion-pro-r...D_BwE&sku_id=1002155
- 577nitro
Yup, thats it. If it does't work I'll put it on the ZRX or the KDX200.
577nitro
577Nitro
- 577nitro
- Thank you received: 2301
If you have the electronic's skills to custom build such a system and the time to spend on R&D "why not" I would however suggest a couple of thingsMy EE buddy is getting pretty excited about this project, we've decided to go with a new design altogether and scrap the crashed bike setup. We've found some commercially available stepping motors and controllers that we can program. That will let us have the ability to have "modes" like the fancy bikes. Might be able to integrate into a OBC and TFT touch screen I've been working on for a while using a raspberryPi 4. Need to figure out the throttle though. Or...it can all crash and burn too...
- Activate the system through your kill switch
- Design it with a system voltage around 11v (bleed off the excess through a "zenner" type set up) this will prevent surging on a constant throttle due to system voltage fluctuations
- 577nitro
Good luck
All good info to take in...so many cool things that can be added once we reach being able to control the throttle. I program embedded systems with IMU's and published a few mobile device apps, so that part's going to pretty easy to do. I've been fooling around with a fully integrated bolt on instrument system with GPIO interfaces..however I really never thought of adding throttle or engine manage to it until now. BUT...with throttle control...coupled with IMU's, there's a real possibility of at least a basic level of rider aids.
- 577nitro
I received a 12-1019 and 12-1018 (the 78-80 Z1R OEM cables) as well as a German Made 12-1019 exact copy. I installed them on my Yoshi throttle holder, lubed them the best I could and what a difference. Night and day, and I shit you not. At least a 30% reduction in force required. So much smoother, I was able to back down the spring tension on the carbs because it no longer needed to fight that friction. The German made one was on par with the OEM. And it was bitch to find the OEM's. I need to adapt the Works Connection throttle tube to fit the ISD of the bars, so I'm guessing it will even get better when that is done.
I'll give a ride report on this setup when I get a chance. I'm still working the fly-by wire as well.
577Nitro-
- mikeyt62
- mikeyt62
Thanks for any help
- Dr. Gamma
- Thank you received: 676
Just saw your post. WOW everything is different looking here now!!!!!Hey Dr.Gamma, I noticed this thread as Im trying to set up my 83kz1000r with Keihin 33mm and need to get the throttle setup. I just bought the YOSH push pull throttle on EBAY. Now I need to figure cables. I see your recommendation getting the throttle cables. What about the throttle tube? Where do I get that from?
Thanks for any help
Try using a 1978~1979 GS1000 inner sleeve part number 57110-34601. I used that one on my Yosh throttle. If you can find one the RG500 inner sleeve works too and it is quicker than the Gs1000 one!!!
1986 RG500G 2 stroke terror.
