KZ550 carburetor rebuild - now bike won't run well TK26 CV carbs Help!
- gvin
Re: KZ550 carburetor rebuild - now bike won't run well TK26 CV carbs Help!
24 Oct 2022 13:51Took a look at the spark advancer and looks squeaky clean, moves freely and smoothly.Have you adjusted the valves, and made sure the spark advances moves smoothly? Airfilter in the airbox?
- gvin
24 Oct 2022 13:52Can you please clarify what needles you are talking about?try raising needles 1 notch [ lower clip ] seems lean through mid range, i just done a gpz 550 all stock and it was terrible lean with todays gas. report back
- GpzGreen
12 Dec 2022 16:13
I think he is referring to the jet needle. My Gpz with same carbs is acting the same way.
Bike is stuck in the garage, it will start and idle but bog when given throttle as in your very good video.
Carbureted perfectly before I parked it and all 4 were rebuilt only changing O-rings.
Any new help for us please?
1982 GPZ-550
- gvin
19 Jun 2023 06:49Nothing else. Still unresolved. I adjusted the floats and same problem. Did you fix yours?I think he is referring to the jet needle. My Gpz with same carbs is acting the same way.
- Stig
03 Jul 2023 03:45
Just a thought, could it be a coil problem when hot? Are you getting a good spark after the bike is up to normal temperature. are the plugs the correct ones (not just the right size but the correct number (as this will effect the heat of the plug).
03 Jul 2023 09:47
Just for testing reasons, cover half of the airbox intake with tape and do a test ride.
