Carbs popping on acceleration, etc. 83 KZ750 Twin
  • sharkmonkey
  • sharkmonkey's Avatar Topic Author
05 Apr 2019 10:04
#801584
Ok, I have an '83 KZ750 twin. I just need to verify some things before I go digging in to this.
It will only idle with full choke on after warming up. If I spray carb cleaner around the manifold it will sputter and die. If I use the throttle to rev it and hold it at 3k rpms, push in the choke, rev it more, it will pop through the carbs. So this means I most likely have a lean condition? And probably leaking air around the manifold?
Other possibilities?
Thanks all.
Mark
1983 Kawasaki KZ750 KZ1 LTD (belt)
1980 Honda CM400T
Re: Carbs popping on acceleration, etc. 83 KZ750 Twin
05 Apr 2019 10:48 - 05 Apr 2019 10:48
#801585
sharkmonkey wrote: ............... If I spray carb cleaner around the manifold it will sputter and die. ...................
No doubt about it - the carb holders are leaking and should be replaced. That needs to be done BEFORE fiddling around trying to tune the carbs. Otherwise you not only are wasting your time but you may mess up what are already perfectly tuned carbs that cannot operate properly until the leak is eliminated. Ed
Last edit: 05 Apr 2019 10:48 by 650ed.
The following user(s) said Thank You: sharkmonkey
  • TexasKZ
  • TexasKZ's Avatar
05 Apr 2019 11:28
#801589
Definitely check the things that affect the carbs before blaming them.
The carb holders (manifolds) are crucial. Even a tiny leak can cause mixture and running problems. Also be sure that the carb to air box tubes are flexible and well sealed. Be sure that the air filter is clean and properly installed, and even the air box lid itself needs to be properly in place.
You should also insure that the valve clearances are within spec, as badly out of adjustment valves can give the carbs confusing vacuum signals. Clean fuel is also important.
  • sharkmonkey
05 Apr 2019 17:29
#801611
Good information. Unfortunately the previous owner cut out the air box. I would LOVE to find an original air box and carb to air box tubes.
1980 Honda CM400T
  • TexasKZ
  • TexasKZ's Avatar
05 Apr 2019 18:59
#801616
I guess you will be using individual filters. One of the 750 twin guys here can get you started on the right jetting path to get it running better. Running without filters and with stock jetting will give you a very lean mixture.
  • DoctoRot
  • DoctoRot's Avatar
05 Apr 2019 23:22
#801619
Those use 34 mm cv carbs. It is important to get pod filters that do not block the ports on the bell mouth of the carb. Cheap pods usually block these
  • sharkmonkey
06 Apr 2019 02:40
#801620
Will the carb holder manifolds from a KZ750 four fit the KZ750 twin?
1980 Honda CM400T
  • AtLarge
  • AtLarge's Avatar
06 Apr 2019 06:51
#801624
Nope. To my knowledge no other bikes are similar. You'll probably have to hunt around for a better used pair. Then a very light bead of Honda sealant around the rim on the block so you get a good seal. There are aftermarket snorkels for the airbox but since you don't have one... If you do score one of those though keep it in mind.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
  • DoctoRot
  • DoctoRot's Avatar
06 Apr 2019 19:05 - 06 Apr 2019 19:11
#801665
the 81+ 750 twins have a separate carb setup specific to those years. Parts will be very hard to find as they were made in limited numbers. If you're desperate you could get brand new K&L carb holders for the 76-80 750 twin and run the early model BS38 carbs.
It make be possible to retro fit another carb boot by filing out the bolt holes. I have done this on a KZ400, but it will take some guess work to see what might fit.
Last edit: 06 Apr 2019 19:11 by DoctoRot.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2019 20:53
#801672
You might message Mike and ask him what will fit.
jetsrus.com/mounting_flanges/mounting_flanges.html
  • sharkmonkey
06 Apr 2019 22:25
#801675
I took the carb holders to the parts shop and they were impressed by the good condition they are in. So we used some sealer and put it back together. I also sprayed carb cleaner all through the carbs. Now I can't accelerate at all! It kills the engine when accelerating.
1980 Honda CM400T
  • DoctoRot
  • DoctoRot's Avatar
07 Apr 2019 00:25
#801676
It could be a timing issue. Check your advancer to see if it’s rusty
