Idle drops when shifting from neutral to first
  • dpivas7
  • dpivas7's Avatar Topic Author
12 Aug 2018 12:10
#788714
I have been working on a 1982 KZ750 LTD for about a year now and I finally have the bike running well enough that it doesn't leak any gas or air and but there is still something not right about it...
I had the carburetors cleaned and synced by a mechanic in April. I have put on maybe 200 miles since then. I have always noticed that when I start the bike up (in neutral) it idles fine and I ride away. After about 10 minutes of riding, if I come to a stop sign while holding in the clutch in first, the RPMs will drop really low (not sure, don't have a tach) and the bike dies. If I shift into neutral before coming to a complete stop, it usually will idle and I don't have to keep revving the engine to keep it alive.
I noticed that when I shift from neutral to first, the RPMs drop significantly. I have the idle adjustment screw set so that it can start fine when cold, but once the bike warms up, the RPMs will stay high after I let go of the throttle. If I adjust the idle screw so that the RPMs drop at a normal rate, the bike will die at idle even when warmed up, because the idle is too low. I checked all of the jets and they all look clear and clean. I sprayed some carb cleaner in them just in case but I still have the problem.
Is this a carburetor problem or something else? Is it maybe a clutch problem? I was thinking that my clutch may not be disengaging all the way when I pull on the lever...
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Idle drops when shifting from neutral to first
12 Aug 2018 12:14
#788715
Loosen up your clutch cable a little.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Togoster
  • Togoster's Avatar
12 Aug 2018 12:16
#788716
Does the bike seem like it wants to go forward at a light with the clutch pulled in? Do you have a centerstand?
Get your motor running!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
  • Togoster
  • Togoster's Avatar
12 Aug 2018 12:17
#788717
Did he check the carb float levels? Did he set the idle with a tech of some sort?
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
  • dpivas7
12 Aug 2018 14:00
#788724
I did that but I don't have much left to loosen. It didn't seem to make much difference, but I will try again.
  • dpivas7
12 Aug 2018 14:06 - 12 Aug 2018 14:06
#788725
The bike does not want to move with the clutch pulled in.
I'm not sure exactly what he did, but I checked the float levels today when I had them apart. They were at the same measured height.
Last edit: 12 Aug 2018 14:06 by dpivas7.
  • Togoster
  • Togoster's Avatar
12 Aug 2018 15:24
#788729
Does the bike have a history of drag racing? It sounds like it's not perfect even when in neutral. Check vacuum lines and carb boots for leaks if you haven't already. Choke circuit too, check the plug condition.
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Aug 2018 15:41
#788731
Clear tube method and adjust. Reset the mixture screws to best idle.
  • dpivas7
13 Aug 2018 06:24 - 13 Aug 2018 06:25
#788747
I'll do the clear tube method and see where that's at. I ordered a carb sync tool last night so I can save $150 and do it myself to make sure they're actually balanced. I'm hoping it's only a sync issue.
I adjusted the clutch cable again last night and it didn't seem to make a difference. To my surprise, I actually had a harder time getting the bike to idle in neutral...
Last edit: 13 Aug 2018 06:25 by dpivas7.
  • dpivas7
13 Aug 2018 06:27
#788749
Togoster wrote: Does the bike have a history of drag racing? It sounds like it's not perfect even when in neutral. Check vacuum lines and carb boots for leaks if you haven't already. Choke circuit too, check the plug condition.
Not to my knowledge. It sat for 4 years before I bought it. It was in seriously rough condition, but I was able to ride it 50miles home after buying it.
I actually replaced the vacuum lines, carb boots, and spark plugs in April/May . I'm not sure what the choke circuit is, but I'll look into it.
  • Togoster
  • Togoster's Avatar
13 Aug 2018 07:24
#788752
The tool will come in handy. In no time at all you'll be syncing carbs for others. 150 sounds a bit steep by about double but hey, whatever the market will bear I guess. Tachometer and feeler gauges are nice tools too.
Keep up the fight, you'll solve this.
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
  • Togoster
  • Togoster's Avatar
13 Aug 2018 07:43
#788753
One thing before i start my busy day. The dynamic sync with carb sticks or gauges is the last thing on my tune up list. It is dependent on the overall health of the motor (ie: compression, valve adjustment clearances, etc) proper jetting, a bench sync, a good tune up and well, you get the idea. It's not a magical tool. I know that in every Craigslist ad the panacea for every poor running bike is it needs good carb sync and I don't believe it for a second. That's likely the last thing it needs...literally!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
