- Thank you received: 8
Good news
- stokes
Yes,and nobody expects it to dissolve a solid grain of sand,if that is what is clogging it,the stuttering wont clear up and he will clean it when he adjusts the jets,not the end of the world.I'm not a mechanic,but I would think if there was a piece of grit clogging a jet it would be completely closed and not pass any gas at all,the bike would run a lot worse.missionkz wrote:
LOL.... Carb cleaners work fine for soft gum or some varnish deposits. What I find in slow jets and other tiny passages is hard deposit crud that only a .009"-.012" wire will chase out.stokes wrote: Even in 1st and 2nd,if you rev it high it clears up.I had gumout in the tank and it got a slight improvement now with the stuff the mechanic recommended it seems to be clearing up a lot.I'd like to hear car5cars reasoning on why carb cleaner cannot clean "slow jets"
There is NO SUCH THING as mechanic in a can!
It is as close as you can get to a fool's errand trying clear those tiny holes with over the counter carb cleaner.
1980 KZ1000B Ltd
- Thank you received: 2840
- stokes
1980 KZ1000B Ltd
- Thank you received: 2755
- jimgcastle
- Thank you received: 1
- Thank you received: 2237
missionkz wrote:
stokes wrote: There is NO SUCH THING as mechanic in a can!
You are right, he's in a bottle.
www.homedepot.com/p/Mechanic-in-a-Bottle...ve-2-004-1/202580655
Seriously, valve adjust, then thorough carb clean and adjust is the right way to go.
- stokes
1980 KZ1000B Ltd
- DGA
- Thank you received: 9
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
- stokes
1980 KZ1000B Ltd
- missionkz
WHAT? $350 to rebuild the carbs AFTER he allegedly, already striped the carbs down and cleaned the "low speed" jets!!?? Drivel.swest wrote: I'd get the bike back and do it myself.
Screw that BS! I think he might be a hack.
Buy yourself a REAL factory service manual and get that thing back home. Then ask here what "rubber" parts you can replace (probably for less the $15, no doubt).... then you can learn how to do it right yourself.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- ThatGPzGuy
- Thank you received: 385
These are simple things to do with borrowed tools and some time with the FSM or a Haynes. The carbs don't need to be "rebuilt". Clean the jets and replace rubber bits like missionkz says.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
