- Thank you received: 511
Good news
- bluej58
All you should need to replace are the gaskets and O-rings and I recommend going straight to Kawasaki for the O-rings
78 KZ1000 A2A
- Thank you received: 2829
- stokes
- Thank you received: 8
1980 KZ1000B Ltd
- stokes
1980 KZ1000B Ltd
- stokes
missionkz wrote:
WHAT? $350 to rebuild the carbs AFTER he allegedly, already striped the carbs down and cleaned the "low speed" jets!!?? Drivel.swest wrote: I'd get the bike back and do it myself.
Screw that BS! I think he might be a hack.
Buy yourself a REAL factory service manual and get that thing back home. Then ask here what "rubber" parts you can replace (probably for less the $15, no doubt).... then you can learn how to do it right yourself.
1980 KZ1000B Ltd
- Thank you received: 2840
I know a guy that will do your carbs for less than half that of WG. PM me for details.
- stokes
Okay,they werent clean,but did they work properly?I'm not so interested in cosmetics,if I was I wouldnt have bought a 36 yr old bike.Do you know of bad work he's done,or are you basing "major ripoff" on pictures alone?Nessism wrote: No way I'd send my carbs to Wired George. Major ripoff and I've seen photos of a set of carbs he did for a guy on the GS Resources and they were NOT clean.
1980 KZ1000B Ltd
First of all I've rebuilt dozens of carb sets before and even wrote this rebuild tutorial so I know a thing or two about carbs... zeus.mtsac.edu/~cliff/storage/gs/Mikuni_...Rebuild_Tutorial.pdf
Here is a link to a couple of bashing session about WG from The GS Resources... www.thegsresources.com/_forum/showthread...-Wired-George-Beware
www.thegsresources.com/_forum/showthread...just-won-t-run-right
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
KZB2 650 wrote: I've had my 2 sets of carbs apart more than a few times over the years and its not as hard as it looks...... and for that kind of cash savings I'd sure give it some thought....... good thing to learn anyway.
Agree. Here is a link to a VM carb rebuild tutorial. The KZ version VM's are very similar. Cycleorings.com sells an O-ring kit for a reasonable price. members.dslextreme.com/users/bikecliff/i.../vm_carb_rebuild.pdf
