RS Flat Slide carbs with air box
- daveo
13 Apr 2016 15:56
:huh: Is the consensus generally the opposite with regards to using pods with RS Flat Slide carbs?
My preference is to employ the stock air box with a set of RS carbs coming my way, but would like to hear some experiences folks have had running them that way, instead of with pods. :whistle:
1982 KZ1100-A2
- 9er rider
- Keep a cool tool
Re: RS Flat Slide carbs with air box
13 Apr 2016 18:04
I have implied the same thing,with no answers and looked at carving up my air box and using pvc hot tub flex hose, but then Im putting together another bike and it will be used.So,, I guess if you dont want to sell your air box donate it for the cause and experiment and please keep us informed
13 Apr 2016 18:50
I just had to open the intakes a little to put on bigger hose. I don't think you'll have to do that being you have CV carbs.
- daveo
13 Apr 2016 19:009er rider wrote: I have implied the same thing,with no answers and looked at carving up my air box and using pvc hot tub flex hose, but then Im putting together another bike and it will be used.So,, I guess if you dont want to sell your air box donate it for the cause and experiment and please keep us informed
My experiments thus far on this bike have been based primarily on intuition, and I continue to be encouraged. I'm not a trained mechanic, but have learned from experience that this J-motor is simple to work on, and built like a tank.
I've collected the throttle components needed to adapt from the single cable stock system to dual, using a Kawasaki throttle control that is visually identical to the single cable stock unit, except designed for two. That was an awesome find by itself.
I think the RS will ultimately be better to work with vs. VM33's, and hope to simply extend the existing rubber air-boots forward (10mm+/-) out of the air box to compensate for the shorter front to back length of the RS carbs...assuming that measurement is the same as VM33's. If it doesn't work out, I have a set of K&N pods if necessary.
...am getting pretty geeked-up. :woohoo:
1982 KZ1100-A2
13 Apr 2016 19:03
Keep us up to date.
- daveo
13 Apr 2016 19:04swest wrote: I just had to open the intakes a little to put on bigger hose. I don't think you'll have to do that being you have CV carbs.
Thanks Steve,
Your comment seems encouraging... :ohmy:
1982 KZ1100-A2
13 Apr 2016 19:07
It is as long as it works well for you.
- daveo
13 Apr 2016 19:09swest wrote: It is as long as it works well for you.
I usually go a different way...the road less-traveled.
1982 KZ1100-A2
13 Apr 2016 19:13
I hope you won't be disappointed.
- daveo
13 Apr 2016 19:24swest wrote: I hope you won't be disappointed.
I always try to have an unlocked back door. Last year about this time (while contemplating changing the head and cam), I had the same thought...so-true!
If nothing is ventured, nothing is gained.
I'll hang on to the BS34's, just in case. The beauty of that is they will still be properly tuned if needed.
1982 KZ1100-A2
- kaw-a-holic
13 Apr 2016 19:57
Dave can I ask why you want to used the stock air box?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- daveo
14 Apr 2016 05:44kaw-a-holic wrote: Dave can I ask why you want to used the stock air box?
:huh: If the ongoing debate only applies to pod-use on CV carbs, then perhaps it is time to reconsider.
Besides that, I prefer keeping unwanted environmental elements out of the combustion chamber
1982 KZ1100-A2
