Switched to pods
- Willy1803
Switched to pods
07 Mar 2016 08:09
I got a 1977 kz650B an I switched to pods air filters an having trubble geting it to run right an there's a crankcase breather that's spits out oil can I just plug it or what
- KZB2 650
Re: Switched to pods
07 Mar 2016 08:25 - 07 Mar 2016 08:29
Don't plug it either run a tube on it down by the swing arm or I hooked a K and N breather filter I picked up off Ebay to it...... do you have a header? You will need to jet up a little maybe 17.5 pilot jets and 2-3 steps up on the mains 110s maybe...... I ran 112.5 with the stock motor pods and header and have 117.5s now...... also I've read to check to be sure the pods are not blocking off the air jet at the carb I think its emgo's or some other cheap ones that may.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 07 Mar 2016 08:29 by KZB2 650.
- Willy1803
- KZB2 650
07 Mar 2016 14:50
Z1 Enterprises is a good place also along with jetsrus and the several others suggested....... search ebay for K and N crankcase filter I forgot just what I picked up right now..... (go by the hose size needed (90 degree hose that's attached to the air box) for the opening size coming off the motor and maybe see if you can get a couple other suggestions on this.
1978 KZ650 b-2
07 Mar 2016 15:43Willy1803 wrote: I got a 1977 kz650B an I switched to pods air filters ...
Why? Are you deliberately trying to reduce the performance? :huh: Ed
07 Mar 2016 17:05
Dear moderators,
I think it might be very helpful if someone could compile the carb tuning solutions for each model discussed on this site over the lst five or ten decades and compile the results in a single document per model, and save them in the file base, so when newbies want to reflog this very dead horse, we could point them to condensed wisdom.
I think it would be nice to do the same with MFolk's posting on electrical systems.
07 Mar 2016 17:53
I'm amazed that pod questions still are asked considering the vast amount of information about pods that is available through KZR's great search engine. As far as running pods on the 1977 KZ650, I simply don't get it. Considering that the 1977 KZ650 broke all 750cc speed and endurance records at Daytona, and the fact that those record-breaking bikes used the airbox rather than pods, installing pods on the KZ650 seems like an obvious mistake. Ed
Attachment WORLDRECORDS2.jpg not found
Attachment 00003d-2-3-4.jpg not found
The following user(s) said Thank You: 750Kruzer
07 Mar 2016 18:04
I did it for performance until I found out it cost me at speed. Virtually no stop and go out here. The air box just works better. Still it was hard to go back. My duel pods looked cool and fast. :whistle:
- JaFlo
07 Mar 2016 19:35
Is there a Dynojet jet kit available for your carburetors? If so, I would start there. Some of the Dynojet kits include needles with a different profile that will aid in the tuning of pod filters. If you have cheap pod filters, throw them away and get K&N pods or UNI filters. A wideband O2 sensor and gauge will be your best friend for tuning if you really want to get it dialed in perfect.
08 Mar 2016 02:30Willy1803 wrote: . . . crankcase breather that's spits out oil . . . .
Can result from over-filled crankcase.
- KZB2 650
08 Mar 2016 07:08 - 08 Mar 2016 07:20
F it.
1978 KZ650 b-2
Last edit: 08 Mar 2016 07:20 by KZB2 650.
- Rockranch
08 Mar 2016 07:19www.z1enterprises.com/product/TU40-0376Willy1803 wrote: Could you give me the link for the breather and jets
Vroom-vroom!!!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
