Right back to square one.
  • kzharpe
  • kzharpe's Avatar Topic Author
Re: Right back to square one.
17 Feb 2016 13:27
#711125
swest wrote: Could be fuel starvation. Have you tried running it on prime? Get a can of carb/choke cleaner and spray through the passages. The pilots are very small so a guitar string of strand off a wire brush should go through them to make sure they're clear. Don't hit rubber parts with the spray. Braggarts aside you may have gotten a very nice bike from a guy that was ether too stupid or cheap to get it running right. :whistle: A valve adjustment check should be done before jetting the carbs.
Steve hit the nail on the head. This morning I drained the fuel, filled up with premium, and turned the petcock to prime. Ran like a champ for about 80 miles. However, it sounds like im still chasing a vacuum leak if its running good with the petcock on prime?
1977 KZ650
  • rstnick
  • rstnick's Avatar
17 Feb 2016 14:00 - 17 Feb 2016 14:01
#711134
There are two vent ports on the carbs too, on carbs #2 & #4, purple lines, bottom picture.
There should be a length of hose on each, either coming up and over the air box, or into the air box:
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 17 Feb 2016 14:01 by rstnick.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Feb 2016 14:12
#711136
Mine sit on top of the box. I don't think I would want them in the box. You need to rebuild the petcock. Your leak could be there or the carb holders are leaking. It's hard to tell. I got new ones and everything changed.
  • kzharpe
18 Feb 2016 06:03
#711244
Is there an easy way to check for and find a leak in the carb holders? Also, do you have a link or part number for the specific rebuild kit I would need
swest wrote: Mine sit on top of the box. I don't think I would want them in the box. You need to rebuild the petcock. Your leak could be there or the carb holders are leaking. It's hard to tell. I got new ones and everything changed.
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Feb 2016 06:21
#711253
I resealed my old ones with :ohmy: Permatex, it worked for a while. I bought some from here.
www.diablocycle.com/Carburetor-c-67/
Pics of the carbs could help.
jetsrus.com/index.html
Another place for parts.
jbmindustries.com/
Careful buying on eBay. Some sellers don't care if you get the right parts, all they want is your MONEY. :angry:
  • martin_csr
  • martin_csr's Avatar
18 Feb 2016 07:00 - 18 Feb 2016 13:57
#711261
Carb kits can be a waste of money, since there's usually extra parts to cover a range of models.
aftermarket jet needles sometimes have the wrong taper & the jet sizes may not match the mikuni jets.
I would remove the carburetors from the motorcycle, then remove the float bowls & clean the little parts. then decide what you need. you might be able to read the numbers on the main jets. mine are 92.5. yours probably have a different number. I don't know if the pilot jets have numbers on them. stock is #15.
HF metric nitrile o-ring kit. or viton rubber kit. or eebbaayy. Z1Enterprises.com. o-rings. gaskets. etc.
you might be able to rejuvenate the top gaskets by soaking w LW silicone spray.
Last edit: 18 Feb 2016 13:57 by martin_csr.
  • kzharpe
18 Feb 2016 11:19
#711311
Am I safe to go ahead and ride the bike just setting the petcock to prime? Riding season is about to start and I don't have the time at the moment for some of these projects. I'm hoping I can just ride it till the weather gets cold then this winter I will check valve clearance/replace valve cover gasket and also pull/clean/rebuild the carbs
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Feb 2016 12:57
#711325
You need to check the valves no matter what.
  • kzharpe
18 Feb 2016 13:43
#711336
Yeah kinda the answer I expected. Looks like I'll be ordering a gasket knowing my impatient butt will ruin the original. Any good walk throughs on the forum? Did a search and could find anything specific
1977 KZ650
  • rstnick
  • rstnick's Avatar
19 Feb 2016 07:32
#711454
The carb holders can be checked for leaks by spraying carb cleaner around them while the bike is idling.
If the rpms change, there is a leak.
KZ650 specific maintenance procedures can be found at kz650.info, link in my signature.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
