Dumb Question?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Dumb Question?
03 Aug 2015 17:38
#684133
Here goes...crank, crank...crank.:blink: What is the best way to assure the quickest start, while cranking an engine with BS34 carburetors?
Sometimes it takes an awful lot of cranking before it starts, if it doesn't fire up right-away.
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Dumb Question?
03 Aug 2015 17:48
#684136
Use the choke. Lean is mean. :evil:
  • daveo
  • Premium Member
  • Premium Member
Re: Dumb Question?
03 Aug 2015 18:08
#684140
swest wrote: Use the choke. Lean is mean. :evil:
When cold...yes. :whistle: But my difficulty is usually after turning the engine off after a ride, and then attempting to start it a short time later, while the motor is still warm. :angry:
A friend suggested goosing it a little when turning off the key, to put some extra gas in the cylinder to assist the next start. :unsure:
1982 KZ1100-A2
  • missionkz
  • missionkz's Avatar
Re: Dumb Question?
03 Aug 2015 18:26
#684142
how much fuel mixture do you expect will be in a one through four cylinder engine after 720° rotation while shutting it down?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • daveo
  • Premium Member
  • Premium Member
Re: Dumb Question?
03 Aug 2015 18:38 - 03 Aug 2015 18:42
#684144
Good question...:unsure:
I realize the whole system is mechanical, but don't understand how it gets the initial fuel shot to start, since there is no fuel pump.
Rotating the throttle before pressing the start switch does nothing, except to open/close the butterfly valves behind the slides...
1982 KZ1100-A2
Last edit: 03 Aug 2015 18:42 by daveo.
Re: Dumb Question?
03 Aug 2015 18:42
#684147
The vacuum caused by the intake stroke of the cylinders sucks the air/fuel mix in. Unlike fuel injection no fuel pump is needed to squirt fuel in. Ed
  • daveo
  • Premium Member
  • Premium Member
Re: Dumb Question?
03 Aug 2015 18:53
#684148
650ed wrote: The vacuum caused by the intake stroke of the cylinders sucks the air/fuel mix in. Unlike fuel injection no fuel pump is needed to squirt fuel in. Ed
I can't believe I'm asking about this :lol: , but...how much and when is the best time to twist the throttle to open the butterfly valves? If I just crank it without touching the throttle, it just crank, crank...cranks. :pinch:
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • daveo
  • Premium Member
  • Premium Member
Re: Dumb Question?
03 Aug 2015 19:23
#684152
swest wrote: Plug pics.
Taken in April, after the top-end redo... :woohoo:
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Dumb Question?
03 Aug 2015 20:07
#684158
When starting the bike don't touch the throttle until it fires up. Ed
  • daveo
  • Premium Member
  • Premium Member
Re: Dumb Question?
03 Aug 2015 20:14
#684159
swest wrote: Pic of the bike?
The header has blued a lot since pic was taken in April, apparently due to the head/cam change.
1982 KZ1100-A2
