Dumb Question?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Dumb Question?
04 Aug 2015 07:45
#684239
swest wrote: Got a link to the 33's?
PM sent
1982 KZ1100-A2
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Dumb Question?
04 Aug 2015 08:00
#684245
Plugs look better in the second pic, plug chops I think only really give you a clue what the engine is doing at that instant, hence the WOT and hit the kill switch main jet selection/needle selection procedure. It gets licence busting fast on a 550 let alone an 1100. A pro tuner told me whatever he was doing it had to be WOT, as he looked at a 1340 katana he was doing.
On mine I was getting rich on part throttle but ok on mains, the sooty plugs cleaned themselves pretty quick between chops.
The flatslides are a popular choice, just getting old now so check them carefully if ebaying, someone I know went through several just to find one decent used set.
  • missionkz
  • missionkz's Avatar
Re: Dumb Question?
04 Aug 2015 11:20
#684265
swest wrote: I've seen the tips broken from being tightened too much. Look at it. The PO of my 33's boogered them up, soldered the hole going through them so now I have to find new ones. That's a problem being they are discontinued.
I have a set of 26mm carbs from that $25.00 KZ1000ltd I previously have mentioned... it also has one of the fine point mixture screw tips broken off inside the bore from some knucklehead over tightening the idle mixture screws!! Damn it. No way that carb every let the engine idle right.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Dumb Question?
04 Aug 2015 13:51
#684289
The 33's are hard to dial in correctly. The prices they want for used ones are dishonest being they are obsolete. I paid $100 for mine from a so called friend. Turns out something happened to Miller. His long time clients told me not to trust him, "He's not the same Donny you once knew." I did notice a change in him. He was resentful and angry. :dry:
A year later I went up to the high desert to see him but his house and shop were gone. I never saw him again. The last time I saw him, he had his Honda/Davidson for sale on the edge of HWY 62. That was in 96. :(
I got my 33's working but they had flat spots I couldn't get rid of. The bike sat for 15 years and this time I went through them again, fixed what his brother did and they are working fine. B)
After all these years I'd like to see him again and show him I still have the same bike and carbs. I often wounder what happened to him and did he resolve his problems. :unsure:
