need a doctor here
- nitrokrumpt
- she just looks rough now
1982 kz750-n1 spectre
- Thank you received: 2098
- nitrokrumpt
- turboguzzi
- Thank you received: 72
trouble is carbs work better with bung in place, so you will better get a new set. not a super must, just better
- nitrokrumpt
nitrokrumpt wrote: ...wish i knew how to take a picture from the computer and put it on here....
Here's one way to include a picture (photo, image, etc.) in your post.
Attachment picpostnewsite.jpg not found
- nitrokrumpt
Attachment carb.jpg not found
- Spectre1982
- Thank you received: 9
If you're talking about the bleed pipe (10), I knocked mine out with a flat-tipped brass punch. Use the right size punch so you don't widen the nozzle on the tip of the bleed pipe. Put the punch down the carb body and knock the bleed pipe out through the bottom. Obviously make sure the primary main jet (11) is removed first. Check out my crude diagram.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
- nitrokrumpt
- Spectre1982
1978 Kawasaki KZ200
- Spectre1982
1978 Kawasaki KZ200
- nitrokrumpt
