need a doctor here
  • Spectre1982
  • Spectre1982's Avatar
Re: need a doctor here
20 Jun 2013 15:53 - 20 Jun 2013 15:55
#593238
Don't forget the pilot screw circuit. There's a spring, washer and o-ring at the bottom. Be careful not to lose them. Gently seat the pilot screw and count the number of turns it takes to seat. Then you know where to set it when reinstalling.
To remove the plug, I drilled a small hole and used a pick to pop it loose. Don't go too deep or you may hit the pilot screw itself.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Last edit: 20 Jun 2013 15:55 by Spectre1982.
