Need help identifying....VM29-A7 Smoothbores?
  • BrockSamson
  • BrockSamson's Avatar Topic Author
Re: Need help identifying....VM29-A7 Smoothbores?
10 Apr 2012 15:05
#515051
I have been gone for a while and I need some help.
I was dying to get the bike on the road and gave in and took it to a mechanic. He just gave me a call and said the tool he uses to balance the carbs would normally have fittings it would plug into. He said that he doesn't see those. How do you go about balancing the VM29 smoothbores? Is there a write-up somewhere I can point him to?
  • testarossa
  • testarossa's Avatar
10 Apr 2012 15:11
#515052
BrockSamson wrote: I have been gone for a while and I need some help.
The intake manifolds or "boots" for Kawasakis have the vacuum nipples built into them.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • BrockSamson
10 Apr 2012 15:14
#515053
Ha! Well that explains that... I have new "intake manifolds" that I purchased from sudco for my application. They do not have nipples installed on them.
What should I do? What do I tell the guy?
Thanks testarossa.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
10 Apr 2012 15:24
#515056
Short of getting a set of holders that have the ports, I am not sure of a way to use a vacuum sync on them. There are no ports on the carbs themselves.
Not that I would suggest it, but have read a post on another forum where the poster drilled holes in the carb holders and inserted a port for testing. I would think it would be very difficult to get them to seal correctly but he indicated there were not leaks and they worked correctly.
IIRC the very very early z1 heads had a vacuum test port on them where the carb holders meet the head, but I am not aware of any other heads with these.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
10 Apr 2012 16:03
#515061
Sudco's tuning manual recommends only bench sync and no vacuum sync of 29 smoothbores.
Of course we all ignore this and vac sync them anyhow. :woohoo:
Good Fortune! :)
