Need help identifying....VM29-A7 Smoothbores?
- BrockSamson
25 Jan 2012 01:19
Like the subject line suggests I need help identifying a set of carbs and I was told this is where the most knowledgeable were.
I bought a bike and got an extra set of carbs. I cleaned them up and the markings are as follows:
"Mikuni" "29" "A7"
I used the following sites as resources:
www.postdiluvian.org/~mason/moto/jetting.html
www.motorcyclecarbs.com/images/mikuni/ca...w/vm29explviewLG.gif
I attached a few pictures also. I really appreciate any help. I feel like I have done my research but I get a feeling that I should ask the experts before making assumptions about what I have here.
Thanks everyone!
"Mikuni" "29" "A7"
Thanks everyone!
- saxjonz
- Banned
- KawboyZ
Re: Need help identifying....VM29-A7 Smoothbores?
25 Jan 2012 02:14 - 25 Jan 2012 02:33
Are you the guy who lives in Texas? The one who bought the 200 dollar z? Yeah, those are smoothbore carbs for sure.
There were two stock sizes for the kz's they started out with the z1 as 28's then went to the 26mm later in 80 they did the 28's again but the 29's were definitely the way to go. These were on the kz?
79 LTD B3
Last edit: 25 Jan 2012 02:33 by saxjonz.
- testarossa
25 Jan 2012 07:38
Yep those are definitely 29 mm smoothbores.
BTW welcome to KZR!
BTW welcome to KZR!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
The following user(s) said Thank You: BrockSamson
- jeffasaki
25 Jan 2012 08:14
100% 29 mm smoothies
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
25 Jan 2012 08:25
Hello, BrockSamson, and WELCOME to KZrider!
After clicking on the following link, may scroll down to info and settings for Mikuni 29 smoothbore carbs.
www.z1enterprises.com/reference/z1-carb-guide.aspx
If desired, there is a plethora of info here on KZr about these carbs.
- BrockSamson
25 Jan 2012 10:53
First, thank you very much for the responses and friendly welcomes!
I picked these up in North VA and to be honest came off a Honda CB750. If you Kawi guys don't mind I would like to stick around and document my rebuild effort on the carbs and get advice as I go through the process.
Last night I drained the fuel using those bolts on the bottom of the float bowls and opened up the float bowls (gaskets were shot). I also noticed very minimal tool marks. I am thinking that they are still jetted/configured for the kz1000 which might be good for a 750 with 4-1 exhaust and pods.
I am going to break them down further tonight and will be sure to post pictures.
- BrockSamson
25 Jan 2012 15:18 - 25 Jan 2012 15:38
Ok I am going through the list of parts I have for the rebuild:
Are there any other parts I should consider replacing? Also the Needle Jets are very expensive (15.75 Each). Should I replace them just as a precautionary measure? I want to get a good range of pilot and main jets in the case I am wrong about my tuning assumptions. This rebuild is getting very expensive...either way I do not want to be missing anything important, so let me know if there is something I probably should add to this.
All are in quantities of 4.
Gasket MC Top
Gasket Float Chamber
O-Ring Float Drain
[strike]17.5 Pilot Jets[/strike]
20.0 Pilot Jets
25.0 Pilot Jets
115.0 Main Jets
[strike]117.5 Main Jets[/strike]
120.0 Main Jets
0.9 Air Jet
Jet Needles 5DL31-3
Needle Jets O-6
Thanks again!
Edit:
I will probably be dropping the 17.5 Pilot Jets and 117.5 Main Jets.
Gasket MC Top
O-Ring Float Drain
20.0 Pilot Jets
25.0 Pilot Jets
115.0 Main Jets
120.0 Main Jets
0.9 Air Jet
Jet Needles 5DL31-3
Needle Jets O-6
Thanks again!
Edit:
Last edit: 25 Jan 2012 15:38 by BrockSamson.
- testarossa
25 Jan 2012 16:40 - 25 Jan 2012 16:42
I would recommend that you do replace the needle jet and jet needle. That jet needle acts like a file on the needle jet and over time the hole becomes oblong and makes tuning very difficult. I know they are expensive, but you will forget about that money when your bike is running sweet.
EDIT: Also be VERY careful when screwing the needle jets into the jet blocks! The threads are extremely easy to strip. Actually, you are very lucky if they are not stripped already on one or more of the jet blocks. I know mine were.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 25 Jan 2012 16:42 by testarossa.
- jeffasaki
25 Jan 2012 16:42
Beb very careful when youre removing or installing the main jets
If you crack the jet block youre fucked
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- testarossa
25 Jan 2012 16:43
Jeff types faster than me.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- BrockSamson
25 Jan 2012 16:47
I see you said be careful with the needle jets and main jets. I should be careful with both?
Also, when you say be careful you are saying to just get them in there and not over tighten? Or to just be gentle?
If they are stripped what must be done to fix the problem?
- BrockSamson
25 Jan 2012 16:50
Another question. My bike has a single pull throttle cable that did work with the VM29 carbs. I just assumed that it was pull only (probably showing my inexperience), but after an email to Sudco I am being told I need to have both the push and pull cables and throttle assembly.
I see they offer the Motion Pro Push/Pull throttle assembly and cables. Anyone have experience with using these?
www.sudco.com/CatalogJPG/208.jpg
